belt squeal?
Old Jul 18, 2019 | 10:37 PM
glbeauchamp's Avatar
glbeauchamp
Default belt squeal?
I had a squealing belt so I did the water test, which quieted it down for a while, then came back, so I changed the serpentine belt and it isn't any better. I can't really tell exactly where the squeal is coming from but it has something to do with the belt/pullies. What next? Tensioner? If so, should I just change the pully or the whole thing? Any way to tell if it's bad? It seems to have a little movement when I wiggle it with no belt attached. .
Old Jul 18, 2019 | 10:58 PM
helives4u2's Avatar
helives4u2
Replace both idle and tension pulleys and AC belt
Old Jul 19, 2019 | 10:19 AM
wallysolvette's Avatar
wallysolvette
Also while you have the belt of, scotch brite Th pulleys where the belt rides.
Old Jul 19, 2019 | 12:47 PM
glbeauchamp
Thanks for the input. Last night I gave the idler pulley a shot of WD 40. That quieted it down so I'm thinking therein lies the problem. I am putting a new pulley in today. I will also cleen up the pulley grooves.
Old Jul 19, 2019 | 12:57 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
This video may help !!
Old Jul 19, 2019 | 02:08 PM
glbeauchamp
Very informative. Thanks!!
To belt squeal?
