strange belt problem
Old Aug 26, 2019 | 08:40 PM
jmp's Avatar
jmp
Default strange belt problem
01' auto coupe. so today had to have it towed home, both drive belts off. They just came off, how the hell does that happen? I checked all pullys, they all seem good condition, turn freely, tensioners move freely. Now, I see something strange behind the crank pully there is a piece of rubber like material sticking out, it turns with the crank pully when the engine is jogged. I can't imagine what that might be and if it has something to do with the bely=ts coming off. I that pully also a balancer, could it have a rubber like material on the backside? Please any help would be appreciated. Looks like a big job to remove that pully
Old Aug 26, 2019 | 08:50 PM
namvet6869's Avatar
namvet6869
Harmonic balancer is shot and wobbling . Replace it. Not easy to replace but doable. Find a good mechanic. My replacement was $700.00 which included balancer, front seal, new bolt and labor.
Old Aug 26, 2019 | 08:51 PM
steveb's Avatar
steveb
Sounds like the harmonic balancer going bad. You will probably be able to dig up multiple posts on that issue.
Old Aug 26, 2019 | 08:57 PM
jmp's Avatar
jmp
Youu are correct!!!! I've never come across this before, but thank you for the info
Old Aug 26, 2019 | 11:15 PM
Moved to C5 Tech.
Old Aug 26, 2021 | 06:54 AM
DalecarliaEric's Avatar
DalecarliaEric
Hi, I am also considering changing the harmonic balancer. I found a DORMAN on ebay for $ 87.80. Does anyone have experience with it?
Harmonic Balancer Crank Pulley (5.7L 350 LS1 LS6) for 97-04 Chevy Corvette | eBay
Old Aug 26, 2021 | 09:24 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
I bought a PowerBond balancer from Rock Auto
PowerBond PB1117N PowerBond premium OEM harmonic balancer...
Old Aug 27, 2021 | 11:21 AM
DalecarliaEric
Hi, Thanks for the tip. Just a little thought. Rock Autos GM Original Equipment Engine Harmonic Balancer Center Bore Diameter is 1.50 in. All Daycos HB Bore is 1,481 in. I guess it should work anyway.
Old Aug 27, 2021 | 11:11 PM
grinder11's Avatar
grinder11
I believe you! You've never come across this before because you've probably never owned a C5 before!! I love my car, but the C5 does have some unique faults, this being one of them......
Old Aug 28, 2021 | 02:09 AM
Justin Raney's Avatar
Justin Raney
Do you have any pics of the balancer or rubber that is hanging out? Mine is pretty old as well you can see cracks in the rubber. I noticed a belt noise that sounded like from the alternator pulley marble wobble but may be balancer like yours. I may remove the belt and see if it makes the noise id hate to end up like you stranded with the main drive belt off the car will overheat real quick. May i ask what you mean by engine jogged?
Old Aug 28, 2021 | 09:35 AM
runner140*'s Avatar
runner140*
The harmonic balancer is not a good "thing" to save money on.....buy the best you can afford.
To strange belt problem
