Idle pulley?
Old Dec 15, 2019 | 11:44 AM
Bstan1009's Avatar
Bstan1009
Default Idle pulley?
I noticed a bit of a pulley noise last few weeks eap at start up until car was warm. Had routine oil and filter change and went ahear and decided to change the idle pulley. First time it still had a chirp. So i got another one and that one was quiet. Drove it home and today it is chirping like a mad bird again. Did just experience a ton of rain. Could that be a reason?
Old Dec 15, 2019 | 12:41 PM
Grandpa1's Avatar
Grandpa1
I would check the harmonic balancer and see if it is wobbling.
Old Dec 15, 2019 | 05:10 PM
jim993's Avatar
jim993
If the harmonic balencer is relatively straight-
The swivel bearing in the tensioner can chirp. A clue you may or may not have is fine aluminum sparkles on the belt.
Probably time to change all the pulleys and tensioner. Make sure the dust guards which look like dished washers are not rubbing when replacing.
Drove two 25 minute sessions at Laguna Seca Sunday, heavy rain, no chirps.
It could also be the AC tensioner, tensioner pulley or AC idler pulley.
Old Dec 15, 2019 | 05:34 PM
Bstan1009's Avatar
Bstan1009
can i tighten the tensioner bearings? All pulleys appear to be in good condition upon inspection and i am confused as to why replacing it could fix it but only temporarily??
Old Dec 17, 2019 | 10:20 AM
awches's Avatar
awches
I had to replace the A/C tension unit to stop my chirp.
Old Dec 17, 2019 | 10:50 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
A couple videos that may help you in the diagnosis !!
Old Dec 17, 2019 | 11:43 AM
STRMLNE's Avatar
STRMLNE
Have the belts been replaced recently?
Old Dec 17, 2019 | 12:32 PM
Bstan1009's Avatar
Bstan1009
just the idle pulley. This morning on cold first start of day it had no chirping. I am happy but confused as to how??
Old Dec 17, 2019 | 01:27 PM
STRMLNE's Avatar
STRMLNE
You have 5 pulleys and 2 belts in there. I’m curious how your menchanic was able to single out the idler.
Old Dec 17, 2019 | 01:33 PM
Bstan1009's Avatar
Bstan1009
that makes two of us. I figured maybe I was just out of the loop on that one, but I am glad you said that. I have absolutely no clue. He is a good mechanic, but for sure no corvette expert or specialist in any way. He had no idea about the udders of the vette, or of common reasons for water leaking into passenger floor board. He also reccomnded maybe changing from synthetic to regular to help with my oil leak. That in and of itself isnt necessarily bad advice but considering it is a corvette, I would say it wasnt very good in my case. That is why I used Mobil one high mileage. It was still full synthetic.
Old Dec 17, 2019 | 01:47 PM
STRMLNE's Avatar
STRMLNE
You can take off the ac belt and try and narrow it down the way.
Old Dec 18, 2019 | 12:34 AM
GUSTO14's Avatar
GUSTO14
Bstan1009, you haven't mentioned (at least not in this post) how many miles you have on your engine.
There are a number of other things that could be responsible for a chirp besides the idler. Alternator, A/C clutch, water pump or even power steering. I would certainly check the fluid level in the power steering as a start.
Good luck... GUSTO
Old Dec 18, 2019 | 08:57 AM
Bstan1009's Avatar
Bstan1009
Good luck... GUSTO
my apologies! My engine has 158k milea exactly.
Old Dec 18, 2019 | 09:17 AM
stief's Avatar
stief
C5 of Year Finalist (stock) 2019
My pain in the ***, sometimes chirp ended up being the harmonic balancer. Original equipment at 131k.
Old Dec 18, 2019 | 09:33 AM
Bstan1009's Avatar
Bstan1009
i applied pressure to the HB and it was solid. While running it appears to be solid as well. Once car wss fully dried out it didnt seem to have a chirp, however i havent driven it in a few days due to constant 24 hour rain last few days. When i did crank it last and leave it idle i didnt here any chirping for first time though.
Old Dec 27, 2019 | 09:19 AM
Bstan1009's Avatar
Bstan1009
The car started much more quiet after it had time to dry, however, there is still for sure an annoying squeal/chirp that increases at acceleration. I am going to replace the belt with a gator back this weekend to see if that helps and/or solves the issue. I figure that is the cheapest and easiest trouble shoot from the jump. Idle pulley already replaced, after new belt I will look at tensioner pulley as I know that and idle pulley are lots of the time the culprit and that sometimes soon after you replace one the other tends to go. Ill go ahead and replace AC belt as well. Hopefully its not water pump, harmonic balancer, or anything else serious. I will update my results.
Old Dec 27, 2019 | 11:02 AM
GUSTO14's Avatar
GUSTO14
Good idea, if one is bad, it's likely the other is as well, particularly if they are original on a 158k engine.
Let us know the outcome... GUSTO
To Idle pulley?
Old Dec 27, 2019 | 04:41 PM
Bstan1009's Avatar
Bstan1009
Will do! I didn't have much time to look at it yet, but what I did see so far is that the right side of the belt for sure has a little bit of rough edged from fray where the other side of the belt remains totally smooth. I also notice the sound is coming more from the drivers side of the car. The HB looks to be pretty solid from some angles but from others seems to maybe have a barely visible wobble but it could just be because it is moving so fast. The HB has zero give in any direction when pulled on. A Pulley misalignment may have caused the belt to fray a bit, but I will replace that in the morning and see If it corrects the issue even temporarily. I will then ID the true culprit(s) and fix them as well. Praying for an easy fix! I miss this car and I can't stand the sound!!
Old Dec 28, 2019 | 05:25 PM
Bstan1009's Avatar
Bstan1009
About to change serpentine belt. Before I do I just wanted to ask some questions. Since.replacing the idle pulley, the squeal/chrip at idle has been greatly minimized but increases with acceleration and decreases with deceleration. It seems to be more on the driver side for sure and the edges of the belt are frayed on both sides. What do you think is the underlying issue?
Old Jan 20, 2020 | 06:00 PM
Bstan1009's Avatar
Bstan1009
Default Fixed!!
Sorry for the late update. I installed a new serpentine belt, gator back, and the sound continued. I replaced the belt tensioner and pulley and it solved the issue!!! So happy for an easy and cheap fix and at least i got a superior quality and newer belt to last me a while. There is still another EXTREMELY faint sound coming from some pulley or something but the original squeal/chirp has dissipated 99% and is only noticeable if i keenly focus on it specifically and intently. Thanks for the tips everyone! It was in fact the belt tensior!
