Fog Lamp help!
Old Nov 23, 2002 | 12:48 AM
Quick Brick's Avatar
Quick Brick
Default Fog Lamp help!
I did my heads and cam no problem but adding some fricking fog lamps is driving me :crazy: I Bought the 1100X's made brackets, laid in the harness etc. Popped the new factory switch in since my car did not come with fogs. I T-tapped into the puprle wire near the fog relay no worky :smash: I probed all three or so purple wires with no luck :confused: The factory relay clicks and the #6 fog fuse powers up. So where is my turn on wire? Also the amber indicator lamp in the factory fog switch is not illuminating, but it is controlling the relay. TIA I am putting the hammer up and going to bed :sleep:
Old Nov 23, 2002 | 01:55 AM
gmblack3's Avatar
gmblack3
Default Re: Fog Lamp help! (Quick Brick)
We did ours per this link and it came out fine:
https://www.corvetteforum.com/techti...=130&TopicID=1
I was not the wire-man. I did the lite installs and the wires up front while the other guy spliced in the wires.
