Driveline shake - worse after diff mount install
Old May 11, 2020 | 09:05 PM
2001z066's Avatar
2001z066
7th Gear
Default Driveline shake - worse after diff mount install
New to me, stock 2001 Z06 with 54000km on it.
I would experience this drive line shake in 2nd gear when fighting for traction / when the car starts hooking up after spinning under WOT. Sometimes badly, sometimes not noticeable.
After some research, it seemed that an aftermarket diff mount would solve this issue by securing the rear diff/trans. I bought and installed an RW engineering mount (wouldn't recommend it by the way, the fit wasn't perfect and the mount sits directly on top of the factory rear brake lines - they had to be rerouted slightly and secured in other means besides the factory plastic holders).
The drive line shake is now worse. I can duplicate the symptom every single time in 1st gear and 2nd gear when fighting for traction. The noise is nasty - like a metallic noise, and sounds like its now coming specifically from under or forward of the shifter area.
Anyone have similar experience? Urethane motor mounts make this situation any better?
Old May 12, 2020 | 11:54 AM
dskinsler83's Avatar
dskinsler83
Solid mounts potentiate vibrations, solid type motor mounts will increase any vibrations from the engine side of things.
Old May 12, 2020 | 05:40 PM
SilverBulletVette's Avatar
SilverBulletVette
Sounds like your torque tube
Old May 14, 2020 | 07:26 AM
oharal's Avatar
oharal
Yeah I'm with SilverBullet sounds like your driveshaft couplers inside the TT may have gone. Maybe post a video?
Old May 14, 2020 | 08:06 AM
robmiz's Avatar
robmiz
Did you check the height of new diff mount is taller? Or look at the shifter mount to tunnel frame gap is too close? That might be your metallic noise. Years ago I bought a replacement diff mount and it was slightly taller which I didn’t notice until afterwards. Well this taller mount raised the torque tube closer the tunnel frame. The closest contact point is at the shifter mount on the torque tube. There should about a 1/4” gap, but it was about 1/16” and it bang against the tunnel frame badly.
Old May 26, 2020 | 12:48 PM
2001z066's Avatar
2001z066
7th Gear
I looked under the car a few times since the install. Can't see anything out of place. I will pay attention to the shifter mount next time.
I have since installed a new set of Nitto NT05s. The car hooks better but still has this issue. Rolling into the throttle a bit prevents the shaking i'm having.
If it is a torque tube / flex disc problem.. I'll probably wait until it gets much worse before I am dropping the torque tube!
Old Jun 1, 2020 | 03:43 PM
ASRoff's Avatar
ASRoff
If it’s a Torque Tube issue, you are going to want to address it sooner rather than later... while the parts are still good...
To Driveline shake - worse after diff mount install
