My ABS saga
Old Jul 19, 2020 | 11:59 AM
  #61
skrimshaw90's Avatar
skrimshaw90
If you reference post #4 theres a picture of it, passenger footwell next to the bcm. There are 2 combs, the one youre looking for has about 8-10 wires on it. The serial wire that communicates with the abs module is the light blue on 5 from the end.
Old Jul 19, 2020 | 03:27 PM
  #62
helphos's Avatar
helphos
Originally Posted by skrimshaw90
If you reference post #4 theres a picture of it, passenger footwell next to the bcm. There are 2 combs, the one you're looking for has about 8-10 wires on it. The serial wire that communicates with the abs module is the light blue on 5 from the end.
Thanks! Here's a piece of data for you to consider: I had a wet floor early in my ownership of this 2003 C5 (about a year ago). It came from a blocked AC drain. I'm wondering if your car had a similar issue at some point and the wetness might have caused this issue (or at least contributed to it). As I noted earlier, I have a lot of the same codes you have, and I'd sure like to have a functioning ABS and TCS.
Old Jul 19, 2020 | 03:43 PM
  #63
skrimshaw90
Mine was in a front end collision with a lot of spliced wires.
I found the harness to the yaw rate was cut so I fixed that. Now it's just code c1282 and c1283
Old Jul 19, 2020 | 03:58 PM
  #64
Speedy007's Avatar
Speedy007
Finally some light on the situation..It was in a accident and was re wired incorrectly.
Old Jul 19, 2020 | 06:28 PM
  #65
skrimshaw90
Just cleared all of the codes.
So the car had a lot of splices, specifically at c102 next to the battery. The serial data and swps wires were both light blue. Whoever soldered them back together originally did it backwards, i switched them around and zero codes!
Old Jul 19, 2020 | 06:55 PM
  #66
Speedy007's Avatar
Speedy007
Nice..glad u kept hunting the wires down .
Old Jul 19, 2020 | 08:23 PM
  #67
helphos's Avatar
helphos
Default Resolution!
Congratulations! Glad you got to the root of the problem.
I'm gonna look at the 'comb' area near my BCM to see if I can find an analogous situation to yours, possibly caused by corrosion in that area.
Since it was useful to you to have a second C5 to help with the troubleshooting, I may just have to buy another vette to go along with my Anniversary Edition convertible to help me solve this problem! (I wonder what the wife will say about that?)
