Harmonic Balancer Install Question
Old Jul 19, 2020 | 04:07 PM
TDLW's Avatar
TDLW
Default Harmonic Balancer Install Question
Two questions here:
1-What do I use to measure the depth of the nose of the crankshaft in the bore of the harmonic balancer? The digital micrometer I have doesn’t really work for measuring depth.
2- When I removed my stock HB bolt, there was an oily substance behind the bolt in the crank. It seemed lightweight to be engine oil, but it was dark. I am pretty certain this was the first time the HB bolt had been removed as there was a ton of orange-looking thread lock all over the threads and head of the bolt. Thoughts?
Old Jul 20, 2020 | 07:59 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
1- no, just press it on and you will feel it bottom out against the oil pump when it is seated
2- spray some brake cleaner in the crank snout and blow it out with compressed air
That's how I did it..........Oh, and use an ARP bolt, too.
