Ground clearance
Old Feb 6, 2021 | 04:07 PM
Highmountainpete's Avatar
Highmountainpete
2nd Gear
Default Ground clearance
I just purchased my first corvette, a 2002 corvette c5, have not got it home yet since it is in the middle of the winter here in Sweden.
in somewhat of a worry mode right now not being sure about ground clearance since my garage has a 2 inch edge just at the door and the c5 i purchased has front spoiler and side skirts.
Biggest worry i have now is that the front spolier or skirts will scrape, so im asking here for some input.
anyone that can help me calm my nerves?
Old Feb 6, 2021 | 06:48 PM
robmiz's Avatar
robmiz
What is the measurement at lowest point on the front end? I would measure it...
My vette is lowered all the way on stock bolts and I stored it away for the winter. There’s ~2” edge on the entrance, my air dam is pretty low so I just back it in. I never it heard the front rub or scrap.
If I was you I would slowly back in and see how much clearance you have... it might be close since the skirt and spoiler extends front further out...
Old Feb 8, 2021 | 12:47 PM
silver50's Avatar
silver50
Also if it’s got skirts fitted there’s a fair old chance someone has lowered it too. Either on the stock adjusting bolts or aftermarket. At least they can be raised up again with relative ease.
I had to make a ramp so as one side of my car wouldn’t scrape and that’s with no lowering (yet..) and no front spoiler fitted!
Old Feb 9, 2021 | 11:45 AM
Lespaul66's Avatar
Lespaul66
I had same problem last spring and this was my solution...there is only 70mm clearance from the rubber spoiler to the ground and groung clearance maybe 90mm, no problems Any more. I also first used reverse gear in order to drive it in but floor was almost hitting to the concrete, this is better now.
To Ground clearance
