HRE 547's on Front - Need advice fast.
I'm stumped on whether to order the 18 x 9.5 547's and buy 2 18" KD's size 265/35 or order the 17 x 9 and keep my current 255/40 KD's. (The rears will be 18 x 11 295/35.)
Any pics of 547's on 17" vs 547's on 18"
Re: HRE 547's on Front - Need advice fast. (MarkFLC5)
I have the 546's that are 18x9.5 with the 265-35 on the front of mine. Hope this help's! :cheers:
[Modified by Dale RED 98, 1:59 PM 12/17/2002]
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
There is no right or wrong here....something you need to decide.
For that kind of coin, I'd pony up the few extra bux for the 18's and 2 extra tires. The 18's will look and handle better, and afford you more room if you ever want to get bigger brakes.
If you'd rather save that money, then get the 17's.
:cheers:
:cheers:
18's all the way around look better than the 17/18's... Believe me I have seen many cars with what you are talking about...
On the other hand 18/19's look the best... JMHO... :yesnod:
vetterdstr :cheers:
vetterdstr :cheers:
Re: HRE 547's on Front - Need advice fast. (vetterdstr)
vetterdstr :cheers:
vetterdstr :cheers:
i moved to 547's 18's on the front and have never regreted the switch. I am using Sport Pilots in size 265/35 and work fine. I LUV my 547's! :flag :yesnod: :steering:
Re: HRE 547's on Front - Need advice fast. (EMDExpress)
Check around for a post by MySea5. He is on many of the SW Events posts. He has pictures of his new 547's with 265/35-18 on front. For the money you are about to spend, I would not even consider staying with 17's. Go 18. Just my .02.
The 17 looks too small in the wheel well.
vetterdstr :cheers:
vetterdstr :cheers:
St. Jude Donor '03
The overall tire diameter will be about the same (slightly shorter with the 18's actually)...but the wheel is bigger. You're spending all this money to look at the wheels, right? More wheel looks better, everytime.
I'm pretty sure I'll be going with 19/20's for the same reason, only moreso. Bigger wheels, less tire = :cool:
Re: HRE 547's on Front - Need advice fast. (jschindler)
I got a couple of pics which should give you and idea of what it would look like. The first pic has stock size tires. After running both 17/18's and 18/19's, I definitely would go with the larger ones.
My coupe with 17's in front and 18's in back
My Z06 with 18's in front and 19's in back
Here is my setup: 18 front 19 rear.
Click on picture to see it larger.
[Modified by Maverick, 10:53 PM 12/17/2002]
Re: HRE 547's on Front - Need advice fast. (Speeder)
I have 18s all the way around, but I have to agree with those that say 18/19s are the way to go...
Re: HRE 547's on Front - Need advice fast. (Maverick)
Thanks, thats a pretty good comparison of 17's vs 18"'s in front. I prinetd both pics and even though I lose color, I could still make the distinction as the distance of the shots look pretty proportionate.
[Modified by MarkFLC5, 11:29 AM 12/18/2002]
Damn ... the 18/19 combo looks killer ... and you can possibly get the 345/xx/19's like NoMercy has ...
Re: HRE 547's on Front - Need advice fast. (AP)
http://forums.corvetteforum.com/zero...876732#4876732
I went with 18x9.5/18x11 547's for several reaons.
Mainly because I had been through ~6 months of hell trying to get wheels and tires from two different sources (not HRE) and RG @ Exit28 had a set on order already and at a great price.
The 17" 547's look good, don't take me wrong, but the spokes are shorter and look squeezed down to me. As far as 18/19 combo goes, I had already decided to go with the 18" rear because Mich Pilots in 295/35/19 are .3" shorter than the 295/35/18 and I wanted to keep the front to rear height ratio closer to stock for A/H reasons. Probably wouldn't make a bit of freakin' difference though.
I am sure that I made the final decision based on the fact that RG could get them to me at a great price and quickly as I was really tired of jacking around with the other guys.
Ultimately, do what make you happy :thumbs:
