Pressure from exhaust
Old Dec 2, 2021 | 04:13 PM
1wholikescars's Avatar
1wholikescars
Default Pressure from exhaust
Hi guys,
I have what may sound like an odd question: if you put your hand at the exhaust pipe, and you have dual pipes, should the pressure coming out feel the same on both sides? I am going to do a leakdown test to verify, but I find it someone weird that one side seems to push the exhaust out harder than the other side.
Any thoughts? Is that normal at idle?
Car is a 2003 with replaced engine (LS3) and a respectable somewhat lumpy cam.
Thanks.
Old Dec 2, 2021 | 05:08 PM
mmartinez's Avatar
mmartinez
I would perform a compression test on the engine.
Old Dec 2, 2021 | 06:36 PM
Che70velle's Avatar
Che70velle
It’s irrelevant with an X or an H-pipe.
Old Dec 3, 2021 | 12:11 AM
mmartinez's Avatar
mmartinez
It is irrelevant with an x or h pipe, it only applies if the car has separate duel exhaust.
To Pressure from exhaust
