Car hits rev limiter after trans rebuild and tune
I recently got my transmission rebuilt and had a shift kit put into it. The problem is that now when i go WOT, the car will hit the rev limiter a couple times before it shifts. Obviously this is not good for the motor and I am not sure where to start. I also had the car tuned at a local shop here in dallas after all the work was done. Can someone give me some insight as to where to start to get this fixed before i blow the motor? Attached is the build sheet for the transmission with all the work done. Car has heads/cam/intake etc. A4 with a 2800 stall. It was a 2.73 car and i put a 3.15 gear in it as well. It also gets extremely got inside the cabin if I drive for more then 30 minutes.
Hot inside the cabin after 30 minutes in Dallas? Unless you're running A/C, TOTALLY normal C5 trait. The rev limiter is obviously NOT! This is probably 99.9% a tune issue. You say it was tuned. I'd be headed back to the tune shop today!! Best of luck to you......
The following 2 users liked this post by grinder11:
C6Z_LS7 (06-08-2022),
Toys4Life C5 (07-20-2022)
Received 19,293 Likes
'20-'21-'22-'23-'24
Moved to C5 Tech.
and I appreciate knowing now to start with the tune. I’ll reach out to the shop and see if they can fix it for me! Thank you! Didn’t know if I needed to start with trans shop or tune shop. Lol!
The following 2 users liked this post by RonSSNova:
Toys4Life C5 (07-20-2022),
vette4fl (06-07-2022)
I believe that the reason is the gear change most likely. The ECU shift points and gearing/speed are related. That needs to be adjusted. The 273s were taller and the 315s are shorter so the speed at RPM changed - something along those lines. The guys in the Scan and Tune section will know immediately. I am thinking that the at the WOT shift the 273s were at a higher speed and the ECU is still looking for that speed but it hits the engine rev limiter due to the shorter 315s.
When you go from 2.73 to 3.15 rear drive ratio, the power control module must be reprogrammed OR you will hit rev limiter at WOT, usually in 1st or 2nd. Since 3.15 is a factory available ratio for a C5 A4, a knowledgeable GM dealer can do the reprogram--- but the reprogram will be based upon stock engine and transmission performance.
A BIG additional but-- With the performance cam and non factory shift kit, my opinion is that you need someone who is very experienced in C5 A4 characteristics and the cam performance to do the reprogram.
When I went from 3.15 rear drive ratio to 3.73, my car would hit rev limiter in 2nd and not upshift at WOT. I had A&A Corvette in Oxnard, CA do the reprogram. All good seven years and 15 track days later.
With regard to hitting the rev limiter, the C5 rev limiter is a fuel cut off and not nearly as hazardous to the engine as an ignition cut off. I have managed to hit rev limiter at least once or maybe three times on every session for the last fifteen track days and 45 sessions-- and my 2001, 118,000 mile, 24 track day A4 C5 seems fine.
I do worry about the stock A4 sun shell though. On my list.
Grinder is right. It’s the tune. I’ve been here before. Go back to the tuner, hopefully they are open to listen to you, or find a new tuner!
It is your gear change from 2.73 to 3.15. Don’t do anymore WOT until this is fixed… On the A4s, it’s the Vehicle Speed Sensor (VSS). The VSS is located in the diff, and it needs to be adjusted in your tune. If your tuner can’t figure that out, get a new tuner.
If you ask me how I know, I went through 2 melted clutches torque converters, a transmission until I figured it out through my own knowledge. Incompetent tuners. That’s why I hate most tuners out there because they think they know everything, they ruin your car, then blame mechanical parts and continue ruining other cars such as yours.
Come on u should know better than this. if shops would do this they will start getting a good reputation. They don't want the extra money. they make too much already for an hr of tuning wot, not driviablely. And that would eat into their profits that they don't want. They have to keep up buying GRINDER lll his beer. He his the final say before the car goes out the door. How's that going.
I love how everyone is giving their opinion without real experience on the exact issue lol that it’s the trans, ecu, pcm, etc it’s none of those.
@2002xlt - private message me and I can explain where your tuner needs to make adjustments for the VSS for the gear change. If you don’t make this change, you’ll burn through the clutch material in the torque converter and ruin your trans. You’ll thank me.
Benjione (06-29-2023)
Yes, you are right in theory. On C5s, the speed adjustments are controlled in the diff by the VSS not the speedometer. Many other late model GMs are tuned off the speedometer but not the C5. The VSS counts the rotation in the gears and sends that information to the computer to shift. Standard 6 speeds don’t have this problem.
Ed Ramberger (06-08-2022)
I'm with you, Ed. It is in the tune, which I also addressed. I dont see where we were off topic at all.....
I appreciate all the feedback from everyone on this topic. I will be taking the car into the tuner in the next week or so and let you all know how it goes. The shop has great reviews here in Dallas, which is why i took it there, so lets see how their customer service is!!
Part throttle shifts are dictated by mph and throttle position.
When you change gears from say a 2.73 to a 3.42 it will shift by mph but the rpm will be higher than it was before. So the change for the lower gears will be to lower the mph in the tables. Part throttle is pretty much user preference. Easy to adjust.
Full throttle is a different set of tables. It shifts by mph and rpm. The system first sees the mph, then attempts to shift at the rpm in the table.
Mechanically, the trans takes time to shift, so if the mph happens too close to the rpm, it just doesn’t shift. Which it will do after a rear gear change.
The tuner can either drop the mph tables to hit the shift rpm. Or, if the owner wants higher shift rpm, the tuner will raise those numbers. Might have to raise the rev limiter as well.
Shift time can also be reduced. I think stock is something like .25 seconds.
Of course to test all this it’s a straight stretch of road, foot to the floor. 2-3 shift happens near 90 mph. Tuner may not wish to do that. Depends on if you have a safe place to do it.
Hence my comment that they didn’t drive it to test WOT shifts. The customer certainly did…..
