exersizing abs on 99 c5
Old Jul 6, 2022 | 08:49 PM
vet3's Avatar
vet3
Default exersizing abs on 99 c5
how often would you recommend exercising the abs pump, any thoughts would be appreciated, got codes c1243h and c1255h , exercised abs and luckily they cleared . i tested abs by jacking rear of car up putting in gear and bringing it up to approx 10mph, and pump came on.
Old Jul 8, 2022 | 10:20 AM
Rex99Coupe's Avatar
Rex99Coupe
I exercise mine every time I change oil.
Old Jul 8, 2022 | 09:31 PM
vet3's Avatar
vet3
great idea thank you!
Old Jul 9, 2022 | 01:31 PM
roegs's Avatar
roegs
How do you do it - same way on jackstands? If so, could either of you expand on the process?
Thanks!
Old Jul 9, 2022 | 03:23 PM
vet3's Avatar
vet3
jack up rear of car , blocked front tires. put it in gear tried to go 10mph and abs pump came on. simple as that....
Old Jul 9, 2022 | 08:30 PM
Americal's Avatar
Americal
No need to apply brakes?
Old Jul 10, 2022 | 08:02 AM
Rex99Coupe's Avatar
Rex99Coupe
Thanks!
When changing oil my front tires are on ramps, so jack up the rear and start the car, in first gear just let it idle and it will activate the pump. Let it idle long enough for pump to activate several times.
I also use concrete blocks with 2x6 on the rear instead of jack stands.
Old Jul 10, 2022 | 05:13 PM
seagem's Avatar
seagem
The first snow. Does ABS and traction control,
Old Jul 14, 2022 | 02:23 PM
johnson-rod's Avatar
johnson-rod
I do it about 4 times a year. Once a quarter. I don't drive enough anymore to use the oil change frequency but sometime during each 3 month period I have it up in the air for something.
Old Mar 20, 2026 | 12:55 PM
irfgt's Avatar
irfgt
I have found that if you simply turn the ignition switch on and do not start the car, the brakes will bleed just fine.
Old Mar 21, 2026 | 04:20 PM
streetstrip's Avatar
streetstrip
2000 frc here, do it every time it's up in the air!!!!
Old Mar 22, 2026 | 01:34 PM
RedC5's Avatar
RedC5
Michigan turn arounds - I do a slight drift just about every cold morning going to work! Turn wheel all the way left and blast! That’ll get the lights going!!!😝
To exersizing abs on 99 c5
