Steering Wheel Squeak
Old Jul 6, 2022 | 10:00 PM
Davko298's Avatar
Davko298
Default Steering Wheel Squeak
When I turn my steeringwheel, I hear what seems to be a squeaking noise. It's coming from right behind the steering wheel, sounds like plastic rubbing against itself. From searching the issue, older threads describe spraying silicone under the rubber boot/cover on the steering column in the engine bay, but that wouldn't seem to make sense since it sounds like it is coming from right behind the steering wheel. Has anyone else experienced this issue and resolved it? Any photos or advice would be appreciated.
Old Jul 7, 2022 | 11:37 PM
dainon's Avatar
dainon
I had this same issue last summer. It does sound counter-productive, but I solved it exactly as you described. I got a can of Blaster white lithium, stuck the straw up underneath the steering position sensor cover (The green ring against the firewall) and spayed a good two to three second shot up under there. It lubricated the rubber bushing inside and my steering groan/squeak/squeal went away. One year later, the problem is still solved.
-D
Edit: this is done inside the car in the driver's side footwell where the steering column passes through the firewall, not from the engine bay.
Old Jul 8, 2022 | 04:34 PM
Davko298's Avatar
Davko298
I just purchased a can of Blaster white lithium, stuck the straw up underneath the steering position sensor cover (The green ring against the firewall) and will be driving home later today. Thanks for the reply "dainon". I hope this works, the squeak is really annoying!
To Steering Wheel Squeak
