2002 vert new gremlin
Old Dec 24, 2022 | 11:17 PM
alankb's Avatar
alankb
Default 2002 vert new gremlin
Driving around town and get in the throttle just a bit on a right hand turn, she stalls and acts like I've turned the key off for a split second. Then picks up and takes off as normal. Traction control off or on or not doesn't make a difference.
I've watched the engine to see if it moves under load and it does not.
Anyone else ran into this?
Old Dec 25, 2022 | 12:00 AM
Dads2kconvertible's Avatar
Dads2kconvertible
Consistent behavior? Fine in left hand and straight lines? Happens at all RPM or restricted to a range? Any codes?
Old Dec 25, 2022 | 12:18 AM
alankb's Avatar
alankb
No codes. Only on right hand turn from almost stop. I thought the engine must be moving and shorting a wire or something, but no movement. It acts a little like when I tried to drive my last one off snowy grass. Traction control almost wouldn't let it move, which is why I mentioned that!
Thanks!
Old Dec 26, 2022 | 05:10 PM
alankb's Avatar
alankb
Thanks!
Anyone?
Old Dec 26, 2022 | 06:11 PM
mmartinez's Avatar
mmartinez
Without codes it will be a guessing game, hopefully it was a one time thing.
Old Dec 26, 2022 | 08:32 PM
RedC5's Avatar
RedC5
Long time ago - my ‘98 felt like it did this once on a right turn into sub. Gas was below a 1/8. Is this possible for you?
Old Dec 26, 2022 | 08:36 PM
DBS99MagRedCoupe's Avatar
DBS99MagRedCoupe
I had loose O2 sensor extension wire short out on a header that was intermittent like this.
Old Dec 26, 2022 | 08:38 PM
alankb's Avatar
alankb
Gas is at 3/4.
Old Dec 26, 2022 | 08:39 PM
alankb's Avatar
alankb
Did that stall the engine for a second?
Old Dec 27, 2022 | 03:23 PM
DBS99MagRedCoupe
It bucked and missed. Wire insulation was melted through and the bare wire would ground out.
To 2002 vert new gremlin
