P0492 Check Engine
Old May 14, 2023 | 06:46 PM
jthornton's Avatar
jthornton
Default P0492 Check Engine
I have a 2004 and got a check engine light, checking the code it's P0492 Secondary Air Injection Bank 2.
I found a fix online at Motortrend and did the flush from the connector on the driver side inner fender and cleared the code. Drove a few hundred miles and the check engine light came back on. Repeated the same flush and after a hundred or so miles the check engine light came back on.
I decide to flush only the bank 2 check valve (located behind the intake manifold or so they say, can't see it) by plugging off the bank 1 check valve. Long story short flushed twice and still got the check engine light.
Now I really didn't want to take the intake manifold off to replace the check valve... well one day I was feeling a bit spirited and did a few 1-3 near redline launches going to town and while in town (1-2) on the way home the check engine light went off. Now the moral of this story is sometimes it pays to blow the carbon out.
It's been a few months and the check engine light has never came on again.
JT
Old May 14, 2023 | 10:04 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
You WILL have to replace the check valve.
There is no free lunch.
Old May 15, 2023 | 06:04 AM
jthornton's Avatar
jthornton
I'll wait and see...
JT
Old May 16, 2023 | 09:49 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ive taken those check valves apart. They use a thick rubber disk to control air flow. The rubber disk bends to allow A.I.R. air flow to happen at a specific cfm. When the disk gets hard, dirty and stiff, it fails to flow the proper air cfm and it trips a DTC due to the O2 sensors not seeing the EXPECTED fresh air flow into the exhaust stream during A.I.R. scheduled operation.
As ztheusa stated, The DTC will be back and you need to deal with that check valve. That flush is just a band aid at best. .
BC
Old May 17, 2023 | 08:46 AM
jthornton's Avatar
jthornton
I'll wait and see... it works for now.
JT
Old May 18, 2023 | 08:41 AM
ztheusa's Avatar
ztheusa
You can lead a horse to water...................
Old May 18, 2023 | 10:46 AM
jthornton's Avatar
jthornton
If it ain't broke don't fix it..................
JT
Old May 18, 2023 | 02:42 PM
h8snow's Avatar
h8snow
JT
Its broke will need to be changed. While the manifold is off great time to replace the knock sensors, and oil pressure sensor. PCV valve and just clean up top of engine cheap and good for another 100000 miles. But that's me.
Old May 18, 2023 | 04:49 PM
jthornton's Avatar
jthornton
If I didn't have a C8 due to arrive in a few weeks and I had another Corvette to drive I might put it in the shop and replace it... so long as the Check Engine light is off I'm driving the hell out of it for a while longer at least.
JT
To P0492 Check Engine
