Key issue, no start
Old May 18, 2023 | 07:25 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
It means that you have contact; be it good or bad... . You wont know if you have proper contact until you throw a LOAD on that circuit. If,, Its a good contact, it will function normally. IF its a bad contact, that pin will become a toaster element and not pass the proper voltage and current.
Let me know if you need any more help.. You have my number..
BC
Old May 19, 2023 | 10:18 PM
Ferg03 Z06's Avatar
Ferg03 Z06
The problem has been solved currently. It would not have been at all possible without the kind and generous assistance from Bill Curlee. I am forever grateful. It was narrowed down to poor connections for the power sources to the ignition switch and the new ignition switch. It was determined with the assistance of Bill that the new ignition switch was faulty. I replaced it with the old ignition switch after cleaning the contacts and the connections in the harnesses/pins, and adjusting the pins for a tighter connection. The car immediately started without hesitation. The amount of joy that I felt is something that I cannot explain. I was at my wit's end with the car and was ready to sell it and move on. The car had not moved in over a year and has only started a handful of times during that time, when I was able to make it work without some miracle and manipulation of the contacts. I have also tested it multiple times since and everything is back to the way it should be.
