PLEASE HELP FAST
Old Jan 23, 2003 | 12:11 PM
402Sam's Avatar
402Sam
Default PLEASE HELP FAST
I went to start the car roday to let it run and the battery was dead. I put a charger on it and the lights flash and there is a ticking noise from the motor. The car will not start still.
Old Jan 23, 2003 | 12:24 PM
carpe dm's Avatar
carpe dm
Default Re: PLEASE HELP FAST (sprayedc5)
You p[robably have a bad battery/insufficiently charged battery. If your car is in storage, you do not need to start it periodically. In fact, unless you run it for a long time and thouroughly warm it up, you are not doing it a favor! Continue to charge you battery, or get a Battery Tender and hook it up for the season. If you still have problems in the spring, get an Optima. :yesnod: :)
Old Jan 23, 2003 | 12:26 PM
Cajun99's Avatar
Cajun99
posted yesterday....might find something helpful in it....
http://forums.corvetteforum.com/zerothread?id=477221
Old Jan 23, 2003 | 12:35 PM
402Sam's Avatar
402Sam
Default Re: PLEASE HELP FAST (Cajun75)
Its weird thou, it is a new battery and there is a clicking noise coming from the motor even when the key is not in the ignition. I can jump start it with the truck and it will run fine. When I try to start it with battery jumper everything clicks and it wont start.
Old Jan 23, 2003 | 12:40 PM
Bill Vett's Avatar
Bill Vett
Check your pos/ neg conections to make sure that proper contact is being made. It sounds like the neg. may be loose and not grounded .
Old Jan 23, 2003 | 12:57 PM
402Sam's Avatar
402Sam
Default Re: PLEASE HELP FAST (Bill Vett)
I checked everything and still nothing.I just want to know if that clicking noise is something important like the ecu or something. I am going to take my battery back and exchange it for a new one.
Old Jan 23, 2003 | 01:24 PM
wwashing's Avatar
wwashing
Try disconnecting the battery for a while (5 minutes), then reconnect.
Maybe you have a stuck relay somewhere and it's draining the battery? :leaving: Good luck! :cheers:
Old Jan 23, 2003 | 04:33 PM
Norris's Avatar
Norris
Default Re: PLEASE HELP FAST (wwashing)
I agree with Washing. Just disconnect the Neg cable and let it set a while. Then reconnect it. Chances are it will start just fine. The approximate time to leave the Neg cable off is about one beer.
Old Jan 23, 2003 | 04:42 PM
Z06 Quin's Avatar
Z06 Quin
Default Re: PLEASE HELP FAST (Norris)
the clicking noise is most likely a relay that doesn't have enough juice to hold it in.......they will do that...
Old Jan 23, 2003 | 05:01 PM
Wt99C5's Avatar
Wt99C5
The clicking noise is normal.
Pull the battery out of the car for charging if it's dead. Get 2 bolts that fit the battery and charge it on your workbench.
Old Jan 23, 2003 | 07:08 PM
402Sam's Avatar
402Sam
Default Re: PLEASE HELP FAST (Wt99C5)
Problem fixed, completely dead battery. Got new one, car works get, now if it would stop snowing so I can drive it sometime this year. :cry :mad Thanx everyone for all the help. :cheers: :thumbs:
Old Jan 24, 2003 | 03:06 AM
Cajun99's Avatar
Cajun99
:hurray: :thumbs: :thumbs: :hurray:
Old Jan 24, 2003 | 08:34 AM
PalmettoVetteMan's Avatar
PalmettoVetteMan
Excellent news! :party:
Old Jan 24, 2003 | 06:33 PM
rebelc5's Avatar
rebelc5
I bought a 2 amp battery charger and keep them hooked to lboth my Vettes when I am not going to drive them for a while. :auto:
Old Jan 24, 2003 | 08:27 PM
Crushinator's Avatar
Crushinator
Default Re: PLEASE HELP FAST (rebelc5)
Where is the best place to buy the battery tender? I haven't started mine in over a week and when I started it today it cranked slow for a second or two then fired up. I'd like to get one of those to avoid a dead battery because of the bitter cold weather.
PS, Glad you got yours fixed! :cheers:
To PLEASE HELP FAST
