After almost 24 years of ownership, my 2000 coupe is still on the original tire pressure sensors and, although they're all still working fine, I'll be needing to get new tires soon and figured maybe I should replace the sensors too.
Last time I checked they were a couple hundred each but now on TPMS.com I'm seeing a set of 4 on sale for $99.98.
They're Schrader 33770 EZ sensors, part #25981210, 315MHz.
Seems like these are the right ones for my car, does anyone have any experience using these?
There are lots of recent threads on this topic. The old OEM style required a magnet for triggering. The new style require a $10 triggering tool. TPMS.com probably sells one and they are available at Amazon.
It is best to trigger each sensor before you go through all the time and labor to mount the tires. Just label each one for the wheel it will go into.
