I have an 02 Convertible. Both the drivers seat and passenger seats slide forward when braking. Surely this is not normal. The car only has 27,000 miles on it so how can it be a broken frame rail? Im new to the group so I've broken any posting rules please be gentle and educate me. Thank you!
So you are saying that neither seat will hold it's position, and will slide all the way forward when braking?
I wouldnt say they slide all the way forward but they slide some then back to the original position. I read that this could be due to worn out seat track shims. It just seems unplausible on a car with only 27,000 miles that this would be the issue unless it's some sort of design flaw. This is my first vette so I was curious if others had this same experience or not.I found this article about how to repair them but you have to remove the seats. https://tech.corvettecentral.com/202...king%20becomes.
Common problem, search c5 rocking seat you will find plenty of threads on the issue and various solutions. Taking the seat out for the repair is not particularly difficult
I have fixed 4 C5 seats with the $20 kit that comes with the shims you replace the rubber ones with on the track. Can be a bit confusing the first time but I feel like I could do it blindfold now.
Good luck with your issue.
Yes it is a common problem and you do have to remove the seats to perform the repair. There are numerous kits available to correct the issue. The degradation is directly proportional to the girth of the individuals sitting in the seats, not mileage.
It is not at all unusual for C5’s to have the rocking seat issue and at low mileage. Low miles does not mean low number of seat position moves; especially if the easy entry feature (for C5’s that have it) is turned on.
Look closely at the first pic and you can see the black wedge in between two nylon bushings. Notice the gap difference between the left and right bushings. That's where the rocking is coming from. Not a difficult repair but I recommend watching a few videos first and just take your time.
