C5 Windows won't go up Help!
05-10-2024, 08:57 PM
3rd Gear
My 2000 C5 convertible Windows won't go up What's my next step
05-10-2024, 09:01 PM
Need a little more info like is it both door switches not working? Best place to start is disconnect the negative battery terminal for 30 minutes. Is there a window valet plugged into your data OBD plug?
05-10-2024, 09:04 PM
3rd Gear
Yes not working on either door. Nothing is connected to the plug in module. The mirror and seat mechanisms still work
05-10-2024, 10:55 PM
If you connect a scan tool will the windows respond to the tool commands?
05-11-2024, 03:40 PM
Try jiggling the driver's side according tub from the door to body. The connection in the tube sometimes becomes loose.
05-11-2024, 04:36 PM
My drinker's window sometimes needs a bit of a tug to go up.
05-11-2024, 09:46 PM
Quote:
Originally Posted by
redzg
What RPO is the drinker's window option?
05-13-2024, 09:50 AM
dads2kconvertible
what rpo is the drinker's window option?
dwo. :d
