2000 Keyless Question
Old Aug 12, 2024 | 11:33 PM
chevyorange's Avatar
chevyorange
Default 2000 Keyless Question
Ok, so, I tried to search the forum but man, it is a bear.
I have replaced my receiver and for awhile everything worked fine.
So, a year later, nothing working.
TPMS works fine. This tells me the receiver is working fine.
So I put a new battery in and did the Learning process. Right after I did it, they thing worked ONCE.
I've tried to re-learn (holding the two buttons down) but nothing.
The remote looks fine to my eyes but I'm thinking it is time to get a new one?
What do you wizened veterans say?
Thanks. Keep Rock Alive!! 🤘🏽🖤🔥🙌🏼 ℁ 👋🏼 Save The Wave! #Corvette
Old Aug 12, 2024 | 11:47 PM
Moved to C5 Tech for assistance.
Old Aug 12, 2024 | 11:48 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Replacement fobs for the 2000 are way more expensive than the -01 to -04 system, that said I would replace the fob first and see if that fixes your issues.
Long term though, the later -01/-04 system is one hell of an upgrade over the earlier tpms/fob system. I converted mine a few years back and the later fobs are much cheaper and have a much greater range of operation
Here's a link to the conversion with part numbers if you want to go that route.
https://www.corvetteforum.com/forums...01-04-wow.html
The receivers are hard to come by but they're still out there. Here's one w/o a case currently for sale
https://www.ebay.com/itm/375177791097?epid=656637929&itmmeta=01J5 4XESQ3YS301HN6NJR1ADGC&hash=item575a56c6 79:gksAAOSwoellnZoE&itmprp=enc%3AAQAJA AAA8BoO2hjnQJNrrBVAKfkLdRiSHmcIzLELcAxUi PirNJzBwiAmA1aECHUFrc9%2B5WgHvX00mMQPO7t SFAKOX%2B4%2BLS1cukwDIvU07%2BzuIHqG2uYKE DyoinW6uukbjUkF3QnnUSvNT%2B0T0jjeu58jcy0 MPvKhyd5L3B0%2FewbaZGJhRAC0Jv1gzzhnwOX6S LVx3oYQzII276g0P0vpaiIApMaI4PMh9hCY%2BH6 7nBeIs9ulR7pZZqahKZch0vWjEwL098mZ%2FCnPl g65VCbqfvvynjS6wRyWO9vf8UfkhGWNU7%2BLmCe 3oXqIGUDkueta2hj82jy84w%3D%3D%7Ctkp%3ABF BM3pu7nalk
****Edit*** sorry, for some reason the forum is putting the puke emoji in the ebay link so it won't work. Just do a manual search and you should find it
Old Aug 13, 2024 | 10:50 AM
jcgunn's Avatar
jcgunn
Take a look for cold/broken solder joints on the remote's PCB
Old Aug 22, 2024 | 09:04 PM
chevyorange
Ok, so I got the eBay keyless fob and it won't learn.
It came with a battery so next step is to put a fresh one in just in case that is the problem.
The numbers on the back of the key fob are different than stock but I bought the 2000 model that said it required. The insides look different too:
Stock unit on left, new unit on right.
Old Aug 22, 2024 | 09:43 PM
lucky131969's Avatar
lucky131969
To 2000 Keyless Question
