2003 LS-1 battery current draw ?
Old Oct 2, 2024 | 08:15 PM
killain's Avatar
killain
Oldtimer
Default 2003 LS-1 battery current draw ?
I had the 2 year old Optima red top battery I install 2 years ago die 2 weeks ago, and today I was doing some cosmetic work and I thought maybe I should put the float charger on it till I'm finished, but when I did I noticed that the under hood light not lighting, and when I put the float charger on the battery and had not green lit but orange ( I have a NOCO genius-1 float charger ) which means the battery was somewhat discharged. So I'm going to lit it charge up and then I thought I'd disconnect the ground terminal and check how much of a parasitic draw is present, does anyone know what the average draw is ? I have an INNOVA 3320 multimeter to check it ?
Thank you,
Old Oct 2, 2024 | 08:59 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Roughly around 25 mA’s…you can use the Reserve Capacity in minutes divided by 4…the C5’s OEM battery was a 100 RC so it would be 25.
Old Oct 3, 2024 | 09:34 AM
killain's Avatar
killain
Oldtimer
Ok, Thank you Rob, I thought I'd see if the battery will hold a charge, so I hooked up my multimettery and I charged the battery last night and it now shows 12.73 volts and I disconnect it and I'll see what the charge is in 24 hours. It is a new battery.
To 2003 LS-1 battery current draw ?
