Cleaning fuel injectors
Old Feb 20, 2003 | 11:50 AM
c5chris's Avatar
c5chris
Default Cleaning fuel injectors
What do you clean the fuel injectors with? Im thinking of doing this to the car soon, the same time i change spark plugs.
Old Feb 20, 2003 | 04:24 PM
scool93535's Avatar
scool93535
Default Re: Cleaning fuel injectors (c5chris)
I had a local shop do mine. They disconnect the fuel line to the fuel rails and connect a pressurized can to the system. They started the car and let it idle until the can was empty. Seemed to smooth my idle a bit.
:cheers:
Old Feb 20, 2003 | 07:20 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Default Re: Cleaning fuel injectors (scool93535)
GM sells one of the "dump it in the gas tank" injection cleaning fluids. 'Tis said to be the best on the market by several techs. Some folks swear by it, others swear at it. I used it on my car at about 20,000 miles, did not notice any help or hurt. Of course, the injectors should be in good shape at that mileage, running Amoco gas.
Old Feb 21, 2003 | 05:50 AM
vettenuts's Avatar
vettenuts
Default Re: Cleaning fuel injectors (Gearhead Jim)
I don't believe that GM recommends injector cleaners. On the L-98, there was a TSB not to use it as it was destroying the injector insulation and shorting them out. Not sure if that holds true with the LS-1, but something to consider anyhow :cheers:
Old Feb 21, 2003 | 06:23 AM
SwissVette_Joe's Avatar
SwissVette_Joe
Default Re: Cleaning fuel injectors (vettenuts)
In the order to have some regular preventive maintenance, the use of an fuel injector cleaner product seems to be valuable.
After discussion with my GM TechDep, they as well recommend the use of FIC from time to time. They even recommend to change the gas brand from time to time due to the helpful effect of their different additives.
Personally, I use RED LINE FI-1 FUEL INJECTION CLEANER, but sorry, I can not give you any factually based results about the success and its cleaning working. My engine counter shows some 15'000mls actually - it is not my daily driver.
However, I do believe that this kind of stuff (FI-1 or similar) may also greatly assist with anti-corrosion protection through out the entire fuel system.
.....and this kind of preventive maintenance is not that expensive at all....
Joe. :seeya :seeya from Switzerland
Old Feb 21, 2003 | 02:21 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
:cheers:
I saw they did the same thing on Speed channel but I beleive they also disconnected some other cables ... I should have recorded that show!
Old Feb 21, 2003 | 02:40 PM
darkmercury's Avatar
darkmercury
I just had mine cleaned and replaced the fuel filter at a dealership... runs much smoother at idle and accel!!! I have about 35400 miles too.
Old Feb 21, 2003 | 10:19 PM
lyonsh's Avatar
lyonsh
My son is a Chevy tech (gloat gloat :lol: ). Everybody at his shop swears by BG44K. Pour it in the tank (they also have a separate version you induce directly for really bad buildup).
And don't forget to clean your throttle body while you're at it - dirty TBs are at least as responsible as clogged fuel injectors for rough idle. :cheers:
Old Feb 22, 2003 | 06:53 PM
Bandit1's Avatar
Bandit1
Chris--Every 5k mi, I use BP 44D and/or BP Fuel Inj cleaner through the tank. At 30k mi intervals I hook up a pressurized can of 3M fuel injector cleaner to the fuel rail and let it power clean. It's just cheap preventative maint. Fuel injectors are expensive and a PIA to replace. Clogged injectors are fuel/power robbing little suckers. Whatever inj cleaner you decide on, make sure it is good quality. Some can dry out the seals prematurely.
:auto:
Old Feb 22, 2003 | 09:11 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
For a suspected clogged injector,we at the dealer mix GM top engine cleaner with gas and inject it into the fuel rail in a pressurized cylinder.The fuel pump is disabled and the car injests the mixture...It works wonders and will unclog an injector 99% of the time :yesnod:
For routine maintenance,go to Wal-Mart and purchase Chevron with Techron tank additive.It is good stuff,and it is the same stuff the GM sells in a different bottle for 3 times the price$$$ ;)
Old Feb 23, 2003 | 07:47 AM
turmat's Avatar
turmat
:confused: Curious as to why you want to do this. What are the indications that your injectors are gummed up? I am reading alot about this in the forum lately and would like to know why people get their injectors cleaned and at what mileage? :confused: :hat
To Cleaning fuel injectors
