Ls1 oil consumption- Good leakdown/compression?
Old May 26, 2026 | 08:41 AM
Jeep43's Avatar
Jeep43
Default Ls1 oil consumption- Good leakdown/compression?
2000 C5 has 157k and uses oil much more than the already high rate GM says is acceptable. Spits black carbon out the exhaust, covers the back of the car and stains the concrete.
I did an LS6 valley pan to try to help and was surprised to see I did not need to grind the boss in the valley to clear so perhaps this car has a later engine and who knows how many miles. I've tried every other option to get this under control and now feel that the only thing left is to re-ring it as per the GM TSB which is obviously a significant job.
But I did a leakdown and compression test and got good numbers on all cylinders, could that be and still need to re-ring?
Also the ring kit in the TSB is discontinued, is there a new recommended ring pack or procedure? The TSB cautions against honing the bores and only replace certain rings but digging this far in I would want to freshen everything up.
Old May 26, 2026 | 09:13 AM
Ltngdrvr's Avatar
Ltngdrvr
Black carbon from exhaust would be fuel not oil.
How often, and how much oil are you having to add?
Old May 26, 2026 | 09:44 AM
lucky131969's Avatar
lucky131969
It helps if share the background.
- Are you the original owner?
- Any modifications?
- Any codes?
- Live data you can share?
- Fuel pressure? Engine vacuum?
- Any smoke from the exhaust?
- How much oil do you consume in what amount of time?
Old May 26, 2026 | 12:47 PM
VETTEYOG's Avatar
VETTEYOG
2024 C5of the Year Finalist - Unmodified
I did the LS6 valley cover on my 2001 a few years ago (around 75,000 miles) because I was seeing oil in the intake. I did have to grind down the casting in my valley, so maybe your car has a different engine in it. I also put a cheap Amazon catch can in, but I still get oil in the can. I think LS1's with higher mile, just like the oil. The oil consumption (at least I think) depends on driving style. If I beat on my car, I definitely see more oil in my catch can, then when driving "normal".
Old May 26, 2026 | 12:48 PM
MetalMan2's Avatar
MetalMan2
Any idea on the condition of the valve stem seals?
Old May 27, 2026 | 05:39 PM
redzg's Avatar
redzg
My thinking exactly. 26 year old elastomers, in a not-so-wonderful environment. Also, which head castings do you have? Unless I've mixed up my readings, a 2000 should be 853's, no?
Old May 27, 2026 | 05:51 PM
Jeep43's Avatar
Jeep43
Cnc Ported ls6 heads, 243's. they have epoxy on the intake ports but looks intact. New small diameter (for dual springs) top hat style seals were installed with no change.
Old May 28, 2026 | 12:54 PM
Prop Joe's Avatar
Prop Joe
CNC heads... Just a thought:
Old May 28, 2026 | 02:37 PM
Jeep43's Avatar
Jeep43
When I did the seals I made sure to use sealant on the bolts that go thru the intake. I used permatex non hardening sealer.
The heads are coming off first to be checked out to see if there is anything wrong with them. Maybe the epoxy on the intake ports is loose (although I would expect to see a drastic difference looking at the plugs).
Old May 29, 2026 | 10:13 AM
redzg's Avatar
redzg
Have you checked your VIN vs production dates to see how early/late in the 2000 model year it is? As you note, perhaps you have the later block — which may mean later oil control rings. Not sure of the implications, but it’s always good to know your parameters.
Also, no leaks? Front main, rear main, oil pan, valve covers?
Kind of hate to say it, but I’m crossing my fingers the epoxy needs a re-application.
Old May 29, 2026 | 12:07 PM
Prop Joe's Avatar
Prop Joe
We used to use the Non-Hardening Permatex #2 where I used to work and the cleaning additives in the autmotive engine oils would attack and soften the permatex #2 leading to many leaks. When you pull the rocker pedestal bolts, see if they are oil soaked in the threads. I hope you find something that's an easy fix. When its going back together, clean, and use the blue NOT red loctite.
To Ls1 oil consumption- Good leakdown/compression?
