2000 auto will not start. HELP!!
Old Jun 15, 2026 | 03:05 PM
mi650's Avatar
mi650
Default 2000 auto will not start. HELP!!
I tried to start it, it turned about 1/2 a revolution, and everything died.
The last time I drove it was yesterday, about 150 miles. The only issue was puling into a store about a mile from home, gravel driveway and I got an ABS warning. My wife stayed in the car while I went in, so I didn't turn it off. I wasn't concerned about the ABS warning anyway, figured it would go away when I shut it off.
I guess I'm hoping just a relay blew, but IDK how to check them. Nothing is working: No lights, DIC, radio, windows... nothing. From the threads I've read before posting, it might be relay 42 or 50, and 50 is in the passenger footwell? I'd have to push it out of my garage to get to that, if needed.
64k miles, battery is 3 years old and strong. I have an Actron multi-meter, just not very familiar with using it.
TIA!
Old Jun 15, 2026 | 04:28 PM
lucky131969's Avatar
lucky131969
TIA!
Start with the basics for any car. Confirm you have a full charged/tested battery. Check your battery cables on both ends for corrosion and security.
Old Jun 15, 2026 | 04:34 PM
mi650's Avatar
mi650
Yep, the battery and cables are gtg.
I didn't say this in the OP, but I hooked my jump pack up to it and still nothing.
Old Jun 15, 2026 | 04:39 PM
lucky131969
So you inspected positive battery connection at the starter, and the negative battery connection attached to the engine block above the starter?
Old Jun 15, 2026 | 08:21 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
TIA!
If you're not familiar with electrical testing take your car to an automotive electrical shop.
Old Yesterday | 08:13 PM
mmartinez's Avatar
mmartinez
How exactly was the battery tested, was it load tested at a auto parts store?
To 2000 auto will not start. HELP!!
