Crankshaft Reluctor Wheel what happens If
I was wondering if anyone has ever had any problems with there crankshaft reluctor wheel on a new motor. I was wondering what would happen if these were to move would they through a code and put your motor into a reduce power state and throw the timeing off and if so does anyone no what code it might throw. Looking for some help Thanks
Re: Crankshaft Reluctor Wheel what happens If (97Redflame)
Is it like a piston return spring? :smash:
vetterdstr :cheers:
Re: Crankshaft Reluctor Wheel what happens If (vetterdstr)
The reluctor wheel is located on the back of the crankshaft. On the side of the block is the crank sensor. As the crank spins the wheel passes by the sensor providing the exact location of the crankshaft. The PCM uses this and the cam sensor, among other sensors, to accurately determine spark and fuel calibration. If the reluctor wheel is moved it WILL effect the performance of the engine. Why are you questioning the wheel?
Re: Crankshaft Reluctor Wheel what happens If (9D9LS1)
I had a motor built and I have a code coming up 10-pcm P1336 and cant figure out why and the car has no power and was wonder if anyone new anymore about this code and if the reluctor wheel was mis alind if this would cause this code to appear and cause the motor to loose power. Thanks for responding to my post. If you know anything else about this please respond. I know this code has something to do with the crankshaft sensor and reading the crankshaft reluctor wheel.
Also I think this code is called a crankshaft learn code. Those are some great looking cars. I grew up in Rome NY. and raced a few bikes at Watkins track. It is a great track way out in the middle of sticks. Thanks again
Talk to Pro Stock John, one of the owners of ls1tech.com. He is the only person I've ever heard of thats had a reluctor wheel problem.
This was on a built motor.
Eric
Eric
Re: Crankshaft Reluctor Wheel what happens If (66ImpalaLT1)
Thanks guys for the explanation... I learn something new here every day! :)
vetterdstr :cheers:
vetterdstr :cheers:
lost,
It is not an intregal part of the crank. Lunati, for example, buys them from GM and presses them on there new cranks. If you heat it with a torch, it will fall right off. I have taken them off before to balance the crank on some balancing machines. If you properly mark it prior to removal your OK!
I was about to mention Pro Stock John. Goo look for his posts on LS1tech. He chased problems for months. The car would launch hard, then fall on its face. It was the reluctor wheel...
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Re: Crankshaft Reluctor Wheel what happens If (J-Rod)
Re: Crankshaft Reluctor Wheel what happens If (CHRIS NJ C5)
I'm not 100% sure thats was causing the problem with John's car, since it was never properly tested its still just a guess. He had a lot of endplay on his crank and thats what they think was the problem, on a hard launch the wheel would move out of sensor range (sounds like star trek eh). Its unlikely that the PCM would lose the signal from the CPS and never set a code but anything is possible..
Has anyone actually had one of those wheels off? I'm just wondering if they are keyed or indexed somehow. I have never had a crank out of one of these yet..
Re: Crankshaft Reluctor Wheel what happens If (kp)
If they have more than .010 runout or the crank has excessive endplay (not sure on that spec - but it is tight <.008) you are in for issues.
Have a GM tech do a crank position learn with a tech II and check the crank position sensor (it's located on the pass side of the block in the back)
Re: Crankshaft Reluctor Wheel what happens If ('97 C5)
What exactly did they do to your motor when it was rebuilt. With some pistons the #8 has to be notched for the reluctor ring. If this was not done the piston can hit the ring and break. When mine was rebuilt no clearance was necessary because my pistons hardly have a skirt. Has the shop that built your motor, built an LS1 before??? That is the first question I would ask.
.010 isnt much room for error. I thing John had ~010-015 endplay (or maybe more) which is a lot for an LS1. I forget what the spec is but .008 sounds about right - it isnt much. I would have hooked a DSO to that sensor and recorded it, a problem would have been pretty obvious. But if the spec was .010 and the sensor ring was on too far forward I can see a problem..
I was curious about how it was indexed since i have seen a couple times where the timing doesnt make sense. Some cars with 11:1 are showing 30 degres with no detonation and a similar compression/cam on another cant go over 22. I realize there are a lot of variables involved, vaccum leaks, injectors. carbon etc. Just curious..
