Removing Crank Timing Gear.. How?
Old Mar 15, 2003 | 03:51 PM
CapeCodCoupe's Avatar
CapeCodCoupe
Default Removing Crank Timing Gear.. How?
I'm installing the rollmaster double chain. First I need to get the stock crank timing gear out and the new one in.. Do I need another special tool?
Any one with tips for r & r this gear? Thanks in advance.
Old Mar 15, 2003 | 03:56 PM
Phil97SVT's Avatar
Phil97SVT
Default Re: Removing Crank Timing Gear.. How? (CapeCodCoupe)
Use a 3 jaw puller. Use fingers and place behind gear, screw center screw in until the gear comes off. If I remember correctly you need to start the crank bolt into the crank.
To intall I pressed the new gear into place on the crank and than used the orginal gear against the new gear and bolted them into place seating the new gear with the orginal crank bolt. Remove the orginal one.
Phillip :party:
[Modified by Phil97SVT, 8:58 PM 3/15/2003]
Old Mar 15, 2003 | 04:05 PM
'97 C5's Avatar
'97 C5
Default Re: Removing Crank Timing Gear.. How? (Phil97SVT)
Phil's got it nailed but I want to add that the roll master set ups that I've installed were both .080 longer than stock, necessitating .080 removal from the harmonic to retain original position.
Measure your stock gear and oil pump drive and compare to the rollmaster. Stock was 1.720 and the rollmasters were 1.800.
Good luck
Old Mar 15, 2003 | 04:23 PM
CapeCodCoupe
Default Re: Removing Crank Timing Gear.. How? ('97 C5)
Thanks Phil ! 97 C5: I have been advised to machine the shoulders of the ASP underdrive pulley by 3mm to accomodate the shims that are used between the oil pump and the block when installing this dual timing chain.
Is this what you are referring to?
Old Mar 15, 2003 | 07:22 PM
'97 C5's Avatar
'97 C5
I meant the overall length and to machine the portion that contacts the oil pump drive.
I do not have a picture depicting this but I have one showing the Rollmaster and pump installed...
[Modified by '97 C5, 4:23 PM 3/15/2003]
Old Mar 15, 2003 | 07:55 PM
Patches's Avatar
Patches
Actually, when I measured mine, the stock and Rollmaster were the same. It really should be of no consequence anyway if you look at the shop manual for installing the pulley. After first torqueing the pulley bolt before the final major torqueing, the manual specification is 0.095"-.175" from the end of the crank to the end of the pulley - an 0.08" tolerance. Mine measured 0.135" so I was right in the middle of the spec. Then we did the final torqueing and the alignment of the pulleys and belts came out perfect. The only machining I did was the shoulder of the ASP pulley (3mm) to clear the spaced-out oil pump.
We did my buddy's the same and it also lined up perfectly. On neither of these pulleys did I take any overall length off. Plus, we measured everything as we installed to assure proper tolerances and alignment. Actually, this is the first I've heard of anyone taking length off the pulley when using the Rollmaster.
:cheers:
[Modified by Patches, 7:59 PM 3/15/2003]
To Removing Crank Timing Gear.. How?
