Changing the front directional bulb...
Old Mar 28, 2003 | 11:00 AM
gkarman's Avatar
gkarman
Default Changing the front directional bulb...
Hi everyone! My first post on this board... I have been lurking too long... and my car has been so trouble free that I have not had to ask any questions before (2000 vert with 23k). But anyways... I am too lazy to read my manual does the directional cover on the front fascia pop off or do you have to reach behind the front fascia to get to the bulb? Thanks in advance!
Old Mar 28, 2003 | 12:48 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Default Re: Changing the front directional bulb... (gkarman)
welcome to the forum!
there are two ways to do this.
this will work if you have long skinny arms.
open hood. manually open headlight. remove bezel (3 screws).
adjust headlight opening for most comfortable arm positioning.
grab bulb, release catch, turn bulb and remove.
be patient and take your time.
Old Mar 28, 2003 | 04:48 PM
gkarman's Avatar
gkarman
Sounds like a bitch... funny thing is I have been to 3 auto part stores and not one of them even has the bulb in stock... looks like i won't be taknig any left turns for awhile (LOL)
Old Mar 28, 2003 | 07:58 PM
LoneStarFRC's Avatar
LoneStarFRC
Sounds like they must not be real "auto parts" stores if they don't stock that one. Hell, you could probably find that one at Wal-Mart!
Old Mar 29, 2003 | 07:04 AM
Oldvetter's Avatar
Oldvetter
Default Re: Changing the front directional bulb... (LoneStarFRC)
Wallmart does NOT stock this bulb. It is hard to fine. I once bought it from a Chevy dealer, cost $10 ! You can use a 3057NA amber bulb, it will fit and looks the same. Get a long life bulb if possible.
I replace from bottom, jack up front wheel/frame at side, remove 5 screws from panel underneath, replace bulb. It's a PITA !
Old Mar 29, 2003 | 07:09 AM
Maineiac's Avatar
Maineiac
From: Making my carbon footprint as BIG as possible
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude '03-'04-'05-'06
Default Re: Changing the front directional bulb... (Oldvetter)
Just push the front brake duct in and down, then you can reach in and change the bulb......takes 5 minutes. :yesnod: :thumbs:
Old Mar 29, 2003 | 08:51 PM
LoneStarFRC
I have found that it is fairly easy to locate. You can use a 3057NA, 3157NA or I believe the 4157KNA now supersedes those two.
To Changing the front directional bulb...
