Has anyone cleaned their MAF sensor???
Old Apr 4, 2003 | 04:22 PM
edmaverik's Avatar
edmaverik
Default Has anyone cleaned their MAF sensor???
Just curious to know if anyone has cleaned their MAF sensors. If anyone has, what products did you use? Any issues encountered?
I "think" I have K&N air filter oil residue on my MAF. :banghead:
Thanks for any advise!
~~Eddie
Old Apr 4, 2003 | 04:51 PM
hayabusa's Avatar
hayabusa
Default Re: Has anyone cleaned their MAF sensor??? (edmaverik)
Man, I have never cleaned one but I have a company van, 2000 chevy, that ran like hell until our mechanic pulled it out and cleaned it. He used window cleaner! Runs good now.
Old Apr 4, 2003 | 05:40 PM
jeanlucpicard's Avatar
jeanlucpicard
Yes, you can clean them. Just about any carborator spray cleaner will work. I have personally used computer spray cleaner. You just spray it on and then air blow it dry - with a can of compressed air (PC users do this) or an air compressor. I would not recommend trying to hand wipe as you can damage the filament wires and ruin the MAF.
Good luck.
Old Apr 4, 2003 | 05:51 PM
turmat's Avatar
turmat
Use contact cleaner which can be obtained from Radio Shack. Just another reason why I DO NOT use a K+N. Heard about this too many times and do nt believe that they are any better than a AC filter. :rolleyes:
Old Apr 4, 2003 | 06:24 PM
Face's Avatar
Face
Default Re: Has anyone cleaned their MAF sensor??? (turmat)
I also use contact cleaner. Especially after re-oiling a air filter. ;)
Old Apr 4, 2003 | 07:46 PM
bparker's Avatar
bparker
I clean mine off about every 6K miles - and or about 1K miles after re-oiling any high flow airfilter.. :cheers:
Old Apr 5, 2003 | 05:12 PM
edmaverik's Avatar
edmaverik
Default Re: Has anyone cleaned their MAF sensor??? (bparker)
Thanks everybody for the input! I cleaned my MAF last nite with a pump sprayer filled w/ 91% isopropyl alcohol and 30 q-tips. There was definitely some sort of gunk! All the q-tips turned black!!!
Last but not least!!! This might sound crazy, but I polished my MAF with my dremel and polishing wheel w/ a slight amount of metal polish! Reason why? The MAF is now screenless and I noticed that there was some burrs when they pulled the MAF out of the casting mold....NOW ITS SLIPPERY SMOOOTH.
Took my vette out on the interstate after a 10 mile warm up and wooohoooo... no more bogging and completely smooth acceleration now!
Thanks again!
Eddie
Old Apr 5, 2003 | 11:36 PM
mozin's Avatar
mozin
Just exactly what is it that you fellows are cleaning? I know the MAF is what is attached to the tunnel but what is inside that needs to be cleaned? I think there is a screen and of course an open area. Are there also some wires that need cleaning? Do you clean the MAF from either end? :confused:
Old Apr 6, 2003 | 12:01 AM
XCELER8's Avatar
XCELER8
Can you give a little more info on where to get this cleaner, what the name of it is, and how much. I am going to do this to my car soon as it gets out of the shop. I have 115k miles on my larger MAF.
Thanks,
Jon
Old Apr 6, 2003 | 11:25 AM
C5kid's Avatar
C5kid
Cruise-In VI Veteran
St. Jude Donor '12
Default Re: Has anyone cleaned their MAF sensor??? (XCELER8)
Went to the dyno and one guy asked me if i had cleaned mine since I put in the K&N, I said no, so we cleaned w/ some carb cleaner quick. Gave me 5 hp proven on the dyno!!!
Old Apr 6, 2003 | 11:27 AM
edmaverik's Avatar
edmaverik
I have no MAF screen, I removed the screen on m MAF because it was very restrictive.
I used 91% isopropyl rubbing alcohol that I had in the medicine cabinet. The pump spray I had is just a plain ol' sprayer that I use with water to spray the plants around the house. I turned thes sprayer to a broad stream setting and sprayed away and let the alocohol do evaporate on the MAF sensor wires!
I hope this helps!
~~Eddie
Old Apr 6, 2003 | 01:09 PM
devo's Avatar
devo
St. Jude Donor '03 & '05
i used about 6 q-tips and contact cleaner, oil from my filter had gotten in there and the q-tips worked great
Old Apr 6, 2003 | 01:31 PM
MTWallet's Avatar
MTWallet
Default Re: Has anyone cleaned their MAF sensor??? (mozin)
You clean the sensor wires that are inside the MAF Sensor. Just be careful and use common sense when cleaning them (don't use 120psi compressed air to blow them off or you cold distort or break them). Just be careful and use rubbing alcohol or carb cleaner and some Q-tips.
Check the pic below to see the wires in question:
Old Apr 6, 2003 | 01:45 PM
mozin's Avatar
mozin
Default Re: Has anyone cleaned their MAF sensor??? (MTWallet)
Are we cleaning ONLY the tiny wires or are we also cleaning the shafts on which the tiny wires are mounted?
I don't notice any driveability problems and I saw from a C5 Specialist that GM recommended AGAINST GM technicians cleaning the wires. If I am not throwing codes should I still clean the wires after 40K miles and only one re-oil of the filter?
Thanks for your help.
Old Apr 6, 2003 | 05:45 PM
MTWallet's Avatar
MTWallet
Its ok to clean everything, just be gentle with it. Don't use anything too harsh, rubbing alcohol or carb cleaner on a Q-tip is perfect.
[Modified by MTWallet, 4:46 PM 4/6/2003]
Old Apr 6, 2003 | 10:32 PM
chuckster's Avatar
chuckster
I saw from a C5 Specialist that GM recommended AGAINST GM technicians cleaning the wires. .
This way thay can get away with selling you a new MAF.. :rolleyes:
Actually, Carb cleaner may be a bit too strong but you can use THROTTLE BODY cleaner..
Take out the maf and shoot the jet right at the wires. The cleaner and dirt shoots right out the other side...
Old Apr 6, 2003 | 10:51 PM
mozin's Avatar
mozin
Default Re: Has anyone cleaned their MAF sensor??? (chuckster)
Are you fellows suggesting we clean our MAF even though we do not appear to have problems, do it just because we re-oiled our air filters?
To Has anyone cleaned their MAF sensor???
Old Apr 7, 2003 | 12:05 AM
edmaverik's Avatar
edmaverik
OKAY...
I want to straighten out the topic out. I was having problems with some bogged down acceleration because I suspected that I had K&N oil oversprayed into/onto my MAF, which is why I posted this thread.
If you are not having any bogged acceleration or hesitation in acceleration, don't clean your MAF. I cleaned my MAF after conversing with a CF member, Jimman, and I went ahead and cleaned my MAF, which made my bogging problem go away.
I hope this clears things up!
Old Apr 7, 2003 | 12:27 AM
mozin's Avatar
mozin
edmaverik,
Thanks. I think I will wait until the next time I clean and re-oil my filter.
Old Apr 7, 2003 | 05:13 AM
rwj383's Avatar
rwj383
if the filaments on the MAF get coated with anything, then it will be sensing less airflow. this will cause the PCM to lean out. On my road trip back home from Montana a few weeks ago i got quite a bit of noticable pinging during normal accel at freeway speeds. As it turned out, my MAF filaments were coated with the crap they spray on the roads up north to melt snow and ice. i carefully wiped it off with q-tips and IPA. NOTE- CAREFULLY. these thermistors are very thin and distort easily. just wipe gently. all will be good then. anyway, my pinging is fixed
