Can you figure the final drive ratio with this info........
Elite Member
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
2nd gear on an automatic, 1500RMP, Speedo says 30 MPH. Trying to figure if the new PCM thinks I'm running the old gears. :cheers:
Re: Can you figure the final drive ratio with this info........ (Mag Red Monster)
on a C5 A4, try this:
determine your C5 rear axle ratio
75mph in 3rd; divide the RPM by 1000
[Modified by Mike Mercury, 2:41 PM 5/11/2003]
Elite Member
Re: Can you figure the final drive ratio with this info........ (Mike Mercury)
if I could go 75 MPH around here I would try this LOL
Elite Member
OK......found out that 2nd gear ratio is 1.62:1 :confused: Is that figured at the trans output shaft?? so if the engine is at 3000RPM the trans out put shaft is spinning at 3000x 1.62= 4860 or 3000/1.62=1851???????
Ok MRM, use this formula,
Engine RPM
________________________ = Wheel RPM
Rear end ratio x Tranny ratio
Wheel RPM x Wheel diameter* x 3.14
___________________________________ = Actual speed in MPH
1056
For your situation at 2nd = 1.62
rear end = 3.42 (?)
RPM = 1500
Speed = 21.4 mph almost 30% error.
What are you running for gearing?
Engine RPM
1056
rear end = 3.42 (?)
RPM = 1500
