2003 LS1 pulling timing -- LS1 Edit -- any down sides??
Old Jun 5, 2003 | 12:16 PM
dmcantrell's Avatar
dmcantrell
Default 2003 LS1 pulling timing -- LS1 Edit -- any down sides??
Hello,
I have a brand new 2003 LS1 convertible, and I recently installed the Halltech TRAP filter system. I live in Dallas and it is getting very hot here lately. I had the car on the dyno, and it was very obvious that the car was pulling timing back quite a bit -- I think the techs said 6 degrees or something.
Anyway, the suggestion was to install a lower temperature thermostat, and do some 'tuning' with LS1 Edit. Are there any down sides to mucking with the car's computer?? What exactly does this software do and whatr gets changed?? I understand that the car is set up from the factory to run nicely anywhere in the US across a broad range of climates (and could need 'tuning' for my specific climate), but something makes me nervous about dorking around with the car's brain when it doesn't even have 10000 miles on it yet... Any input??
Thanks,
--dc.
Old Jun 5, 2003 | 01:14 PM
jimman's Avatar
jimman
Default Re: 2003 LS1 pulling timing -- LS1 Edit -- any down sides?? (dmcantrell)
I have the Halltech sidewinder on my 02 and I'm getting all kinds of detonation. They tell me I need the edit but my 00 didn't for some reason, now a bit confused as you are. Hope someone can enlighten us? :confused:
Old Jun 5, 2003 | 01:51 PM
FRC sexi blk's Avatar
FRC sexi blk
The dyno can be very misleading. What was the temperature outside the time your car was on the dyno? Was there a huge fan blowing air into the front of the car? What other mods have you done to your car?
Old Jun 5, 2003 | 02:51 PM
dmcantrell's Avatar
dmcantrell
Default Re: 2003 LS1 pulling timing -- LS1 Edit -- any down sides?? (cute301guy)
The air temp was near 100 degrees. The water temp according to my guage was 235 degrees!! There was a huge fan blowing air into the front of the car. The Halltech TRAP is the only mod I have done as of yet.
--dc.
Old Jun 5, 2003 | 02:54 PM
IM4A2Z's Avatar
IM4A2Z
Try a fresh set of NGK TR55's Gapped at 45 and put some fresh Prenium Gas from someplace other then your usual stop and then dyno again.
At 235 degrees the PCM will start pulling timing out. :yesnod:
[Modified by IM4A2Z, 2:05 PM 6/5/2003]
Old Jun 5, 2003 | 03:07 PM
jimman's Avatar
jimman
Default Re: 2003 LS1 pulling timing -- LS1 Edit -- any down sides?? (IM4A2Z)
Did the plug rutine, nada try again.
Old Jun 5, 2003 | 03:41 PM
dmcantrell's Avatar
dmcantrell
I've tried the gas from different places -- that was what I originally thought, too.
My car doesn't even have 5000 miles on it -- how can the plugs change anything?
--dc.
To 2003 LS1 pulling timing -- LS1 Edit -- any down sides??
