What should the Normal Battery Voltage range be on a C5 ???
Before I washed the motor my Battery Voltage was a strong 14 V's.. Now it's hovering around 13 V's.
I've had no problems starting my car but I'm concerned that it might be a potential problem in the future.
Should I change my Alternator ?? The battery is only 6 months old..Its an OPTIMA RED TOP.
Thanks !
:cheers:
Jeff
Thanks !
:cheers:
Jeff
Re: What should the Normal Battery Voltage range be on a C5 ??? (BLUTHUNDER)
Washed motor? Maybe your belt's wet and slipping a bit?
Re: What should the Normal Battery Voltage range be on a C5 ??? (mapman)
No Codes and the belts are dry :confused:
I wonder if I damaged the Alternator when I washed my motor ?? I thought all the components were water proof.
Jeff
Jeff
Read this to give you some insight on 12V automotive batteries.
http://www.landiss.com/battery.htm
Re: What should the Normal Battery Voltage range be on a C5 ??? (lt4vette)
My original '98 has been charging from 13.0 to 13.7, when hot 13.2 , and it is over 5 years old.
Thanks Scott !
Good data :yesnod:
:cheers:
Jeff
Re: What should the Normal Battery Voltage range be on a C5 ??? (RedC5)
Received 19,202 Likes
'20-'21-'22-'23-'24
Mine usually reads in the 13's.
Re: What should the Normal Battery Voltage range be on a C5 ??? (JDs00PewterCoupe)
Ok guys I'm new to the site and my voltage usually stays in the 13's but here latley I am seeing some twelves and elevens on dic I work for GM and battery is about three months old and Idk I don't think this is right any help is greatly appreciated
