Tires: 285/40/18 or 295/35/18 with 275/35/18 in front?
Guest
Posts: n/a
I know this is an old old old old topic, but I can't remember what has been said before (getting old I guess). :sleep:
I want to go with 275s in front, but I think I've read that 295/35s may be be too short to go with 275s, and may cause Traction control issues. Should I be concerned? Does anyone run 285/40s? :rolleyes:
Re: Tires: 285/40/18 or 295/35/18 with 275/35/18 in front? (MMI)
I am not sure what rims size you have up-front, but I assume it is 18x9.5
If this is the case i recommend you go with a 265/35/18 up-front and a 295/35/18 in the rear. I just did it and it looks great and there are no issues.
Use the tire calc website below and you will see the differences.
Tire calc website- http://www.miata.net/garage/tirecalc.html
Guest
Posts: n/a
Re: Tires: 285/40/18 or 295/35/18 with 275/35/18 in front? (Wicked C5)
I am currently running 285/30/18's in front with no issues
skar (11-24-2015)
You have no issues because you are running 19's in the rear, so you still have a 1" difference to avoid traction control issues. He is looking for advice for an 18" rim all around, front/rear.
[Modified by Johnny Vig, 1:27 PM 6/19/2003]
What about stock wagon wheels on a '99 FRC? 18x9.5 rear wheels.
OEM is 275/40/18. Are there wider sizes that still look good and are safe to use? 285/35s? 295/45s?
~Matt
[Modified by Matt Black, 12:26 AM 6/20/2003]
~Matt
Re: Tires: 285/40/18 or 295/35/18 with 275/35/18 in front? (4DCYKEY)
Have 265/35/18 frt & 295/35/18 Toyo T1S Proxes on 9.5 & 10.5. No problems and like the Toyo's. If overall diameter of rear to front is greater than 96% there should be no traction control or ABS problems.Less & potential probs when cornering.
Fred K.
Fred K.
Guest
Posts: n/a
Re: Tires: 285/40/18 or 295/35/18 with 275/35/18 in front? (FKING1)
Fred K.
Fred K.
St. Jude Donor '05
Calculate away!
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
A 275/35/18 is almost exactly the same dia as the stock 17" front tire at 25.7". The 295/35/18 is a little shorter than stock at 26.2" (stock is 26.7"). This is right at the 1/2" stagger point, or 98%....and while it should be ok, I'm not gonna guarantee it. :D
265/35/18 or a 285/30/18 would be better choices for the front. Both are shorter in height to better match the slightly shorter 295 rear.
Also,
Calculate away! http://www.miata.net/garage/tirecalc.html
:cheers:
[Modified by Y2Kvert4me, 2:35 AM 6/22/2003]
Guest
Posts: n/a
Re: Tires: 285/40/18 or 295/35/18 with 275/35/18 in front? (Y2Kvert4me)
Yea, I just looked up the Toyo tire height #s:
275/35/18 -- 25.5
295/35/18 -- 26.1
285/40/18 -- 27.0
The 275s up front are key for me, so I don't think I'll chance it with 295s in the rear. I think I'll go with the 285/40s in the rear -- I think they will fill out the wheel well area pretty good too...
275/35/18 -- 25.5
295/35/18 -- 26.1
285/40/18 -- 27.0
