Roll\Sway bars...
Old Jul 16, 2003 | 05:31 PM
C5EVIL's Avatar
C5EVIL
Default Roll\Sway bars...
I wanna order some of these, and I've been told by Bob at Fichtner that the Z06 are the best ones - is this correct, or are there even stiffer ones I can buy for a "performance" package?
I don't wanna buy the Z06 ones if I'll need to upgrade these at a later date?
Old Jul 16, 2003 | 05:49 PM
Richin Chicago's Avatar
Richin Chicago
Default Re: Roll\Sway bars... (C5EVIL)
I haven't put these on my car but I have driven one on a roadcourse with Hotchkis bars the car felt very composed.
Maybe some other people can comment.
https://www.hotchkis.net/secure_index.html
Old Jul 16, 2003 | 05:51 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
I upgraded to the Z06 bars and I don't see where I'll need anything more. They're plenty firm for me!
Old Jul 16, 2003 | 05:54 PM
John's vette's Avatar
John's vette
Cruise-In III Veteran
Cruise-In IV Veteran
IMO the Z06 and Hotchkiss bar are close to the same. If you really would like to step up to the next level and you don't mind a stiff ride, then get the T-1 bars. They are designed by GM for SCCA racing. It is what I have on my car, although they sorta make alot of noise when I pull into the drive way, they hold the road like I am on rails.
Only problem for some is they come Blue, although mine was powered coated Black and they look great.
Old Jul 16, 2003 | 06:14 PM
C5EVIL's Avatar
C5EVIL
Default Re: Roll\Sway bars... (John's vette)
These sound cool - you mention that they're blue - I take it you can't see 'em unless you're under the car, though, right? :confused:
Old Jul 16, 2003 | 06:18 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
I personally like the T-1 bars but if you buy either and try them you can sell them for 75% of new if you don't like it. Mallet makes a bars too. Chucks opinion was the T-1's are to much. What is your car now and are you putting shocks on too?
Old Jul 16, 2003 | 06:23 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
The rear bar is easily visable from behind the car.
Old Jul 16, 2003 | 06:30 PM
C5EVIL's Avatar
C5EVIL
Default Re: Roll\Sway bars... (John Shiels)
My car is a stocker 1997 - has the soft ride suspension, so it all needs upgrading. My plan was to do the bars first, then the shocks - I want my vette to handle like the tyres are made from chewing gum! :D
Old Jul 16, 2003 | 06:53 PM
John's vette
I went from FE1 (base) to T-1 and Bilsteins. I love the change, but it a rougher ride.
Old Jul 16, 2003 | 08:04 PM
SHOWTIME!'s Avatar
SHOWTIME!
http://www.lmperformance.com/810/4.html :thumbs:
Old Jul 16, 2003 | 10:38 PM
bk's Avatar
bk
Default Re: Roll\Sway bars... (SHOWTIME!)
I had the stock z51 bars and have now installed the T1 bars. Huge difference in roll stiffness. The T1 bars are stiff, so the ride suffers a little, but it leaves the car with no body roll at all. I love them on the track. On the stree they are a little noisy though. They are huge and heavy.
(I like the blue look personally.)
Old Jul 16, 2003 | 11:27 PM
Ex_F-Body_Enthusiast's Avatar
Default Re: Roll\Sway bars... (bk)
I'm considering upgrading my stock swaybars as well. The BMR's (32/21mm, solid) look to be a good deal for $349, incl. heim joint endlinks.
For comparison, can anyone tell me the diameters of the T1 bars and whether they are solid or hollow?
TIA!
Cash (prefers not to slow down for corners) Mullen :cheers:
Old Jul 16, 2003 | 11:40 PM
John's vette
Default Re: Roll\Sway bars... (Ex_F-Body_Enthusiast)
The T1's are hollow and the front is 38mm and the Rear is 27mm. The Heim endlinks can be rather noisy.
Old Jul 17, 2003 | 12:54 AM
NVR BRNG's Avatar
NVR BRNG
I have the FE1 Springs like you do (swapping to Z51, killer deal @ $350 for both!), with F45 shocks. I added the Hotchkis bars before I did anything (have you seen the FE1 bars, they are solid, but they are diam. of your pinky finger!) The Hotchkis come with the Heim endlinks too. Regardless of what you select, ANYTHING will be an improvement over the FE1 bars.
What kind of DRIVING are you going to do? If you're on the track at all, I'd go for T1 (Hotchkis & T1 are hollow, Hotchkis worked on the R&D for GM for the T1 bar, do a search on the Forum to find out more....) Can't go wrong w/ Z06 or Z51 either, but you've got good info on this post to make some decisions.
I believe that the Z06 & Z51 bars are solid.
I heard that the Bilsteins are a great value for the money, but I have several friends that while they PERFORM great, they also .complain that the ride is fatiguing on the street. If you want external adjustability, Koni makes a 3 way, and I'm sure that there are other choices.
Finally & obviously, lowering the car to your taste will help with flatter cornering too. Have fun with your upgrades!
Old Jul 17, 2003 | 02:44 PM
Default Re: Roll\Sway bars... (NVR BRNG)
Thanks for the info on both the T1 and the Hotchkiss setups. . .
Can you tell me the diameters of the Hotchkiss bars? Its like I need a spreadsheet with all the different sway bar options out there!
TIA!
Cash (still mulling it over) Mullen :cheers:
Old Jul 17, 2003 | 03:11 PM
Richin Chicago
TIA!
1 1/4" Hollow Front Bar
1" Hollow Rear Bar
https://www.hotchkis.net/cgi-bin/SoftCart.exe/frames/catalog/c5/2234.htm?
Old Jul 17, 2003 | 03:42 PM
aggie_corvette's Avatar
aggie_corvette
Sway bar info.
Specs (mm/in)
T-1
F: 38/1.48
R: 27/1.05
Hotchkins
F: 32/1.25
R: 25/1
Xtreme, BRM
F: 32/1.25
R: 21/.80
Z-06
F: 30/1.18
R: 23.6/.93
Z-51
F: 28.6/1.13
01+ R: 23.6/.93
Std
F: 23.1/.91
R: 19.1/.75
Also solid or hollow has no effect or stiffeness or durability. The outer few thousands of diameter of the bar is what controls the actual resistance to twisting (this is not opinion, look it up in any meterials handbook). The hollow are simply lighter and more expensive to manufacture.
As far as which one is better... depends on what you are willing to give up.
Corner like its on rails = beats up your kidneys.
Personally i'm young and a track type so i am willing to give up a lot...
Will
:cheers:
Old Jul 17, 2003 | 06:00 PM
KingTut's Avatar
KingTut
Default Re: Roll\Sway bars... (aggie_corvette)
The Z06 bar is most reasonably priced and about the stiffest that does not seem to impact straight ahead ride smoothness. It cormers well and goes straight ahead smooth.
The bars above that on the scale are give up some ride smoothness to get even better corrnering. That choice can only be made by you. I think that T1 is the top end and Fitchner sells those also, but they are much bigger dollars also.
Be sure to put one hand on your wallet as you compare Z06 and T1.
[Modified by KingTut, 6:02 PM 7/17/2003]
Old Jul 18, 2003 | 12:18 AM
TexasC5's Avatar
TexasC5
Default Re: Roll\Sway bars... (KingTut)
My FRC is lowered and I went from the stock Z51's to the T1's. The T1's were a vast improvement. I do not feel the ride is too rough and have not experienced any noise. This set up makes the car feel like it's on rails. If you want the stiffest/best performing bars out there then the T1's are worth every penny.
To Roll\Sway bars...
