NEED HELP! Key won't budge
Old Jul 17, 2003 | 07:56 PM
laramr's Avatar
laramr
Active Streak: 90 Days
Default Update: Problem fixed!! NEED HELP! Key won't budge
Car is in my garage, wheels dead straight. A4, 2001 (no column lock issue). Key will not turn at all. Car does recognize key because seat memory works. Tried wresting the wheel and the shifter but nothing worked.
Any suggestions?? :confused: :cry
Update:
Talked to three Chevy service people today. Williams (Elkton, MD), Porter (Newark, DE) and Diver (Wilmington, DE). Two guys had no clue, but the woman I spoke to at Diver had the answer. She suggested a firm jolt to the key while in the ignition (based on her experience with Saturns). Worked like a charm. Can't wait to call her back on Monday and thank her. :cheers: The other guys were ready to send out the tow truck. :rolleyes:
Also wanted to thank everyone here who took the time to either suggest a solution (tried them all), offer condolences or razz me. As always, all replies appreciated. :cool:
Not too pleased about having to treat my car like a stuck vending machine, but the weekend is going to be warm, dry and sunny. The top is already down!!! :party: :party:
[Modified by laramr, 10:52 PM 7/18/2003]
Old Jul 17, 2003 | 08:10 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: NEED HELP! Key won't budge (laramr)
try wiggleing the steering wheel while turning the key... Maybe something was on the end of the key and is now lodged in the ignition
Old Jul 17, 2003 | 08:45 PM
Red C8 of Jax's Avatar
Red C8 of Jax
Try removing fuse #25 behind interior passengers side floor board. Kinda resets everything!! :flag
Old Jul 17, 2003 | 09:30 PM
laramr's Avatar
laramr
Default Re: NEED HELP! Key won't budge (red-C5 of jax)
Tried it. No response. It's not the key. Second key won't work either. Must be a shifter related interlock
Old Jul 17, 2003 | 10:30 PM
laramr's Avatar
laramr
Guess I'm calling the General in the morning! :U
Old Jul 17, 2003 | 10:47 PM
2KVetteMan's Avatar
2KVetteMan
Same thing happen to me when I first got my vette, the C5 mechanic came out, pop the hood took some fuse out, then came back into the car, move the shifter around a little and then bang the car started :crazy: . Never happen since.
Old Jul 17, 2003 | 11:06 PM
texasredc8's Avatar
texasredc8
Well the C5 has an electronic column lock, so it can't prevent the key from turning. The steering wheel isn't the problem.
Could have a bad lock cylinder. Only thing you could try is squirting a small amount (very small) of silicone spray in the lock cylinder and moving the key in and out. May be one of the lock pins thats just stuck.
Old Jul 18, 2003 | 10:55 PM
laramr's Avatar
laramr
Default Re: Update: Problem fixed!! NEED HELP! Key won't budge (laramr)
ttt
To NEED HELP! Key won't budge
