Manual Transmission Fluid
Old Aug 4, 2003 | 05:25 PM
AZGASSER's Avatar
AZGASSER
Default Manual Transmission Fluid
I am looking to improve the shift smoothness of my MN6. Any recs as to which is the best fluid for improving my shifting as well as protecting against wear or the gear? TIA! :seeya
Old Aug 4, 2003 | 05:34 PM
Mark 84ltblu's Avatar
Mark 84ltblu
SE Ohio Event Coordinator
CI-V Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Curise-In V Veteran
Cruise-In VI Veteran
Default Re: Manual Transmission Fluid (AZGASSER)
I put Mobil 1 ATF in the 98. It really smothed things out. Pick your favorite type of synthetic and I think you will notice an improvement.
Old Aug 4, 2003 | 05:42 PM
Elk's Avatar
Elk
I have Redline D4ATF in mine with good results. Many really like Amsoil synthetic ATF. I'm sure Mobile 1 is a good choice.
My guess is that you can't go wrong with any of the good synthetics that are available.
Old Aug 4, 2003 | 06:28 PM
1 BAD C5's Avatar
1 BAD C5
Default Re: Manual Transmission Fluid (Elk)
I just changed mine to Mobil 1 ATF synthetic.
Old Aug 4, 2003 | 06:32 PM
pewterhdtop's Avatar
pewterhdtop
Default Re: Manual Transmission Fluid (1 BAD C5)
Any good synthetic ATF will be an improvement! I use Amsoil, but any one of them is a good choice! :seeya
Old Aug 4, 2003 | 06:38 PM
CapeCodCoupe's Avatar
CapeCodCoupe
Default Re: Manual Transmission Fluid (pewterhdtop)
I changed mine recently to Redline and it does seem smoother. Is the factory fluid not synthetic?
Old Aug 4, 2003 | 06:49 PM
pewterhdtop
Default Re: Manual Transmission Fluid (CapeCodCoupe)
The factory fluid is NOT synthetic. The benefits of synthetic are far greater than smoother shifting. Synthetics are much more heat tolerant, and generally do not get as hot due to better heat conductivity too. :seeya
Old Aug 4, 2003 | 07:04 PM
'97 C5's Avatar
'97 C5
Like the syncromesh synthetic.
Old Aug 4, 2003 | 07:59 PM
C5FAST's Avatar
C5FAST
:iagree: Redine D4ATF all the way! :seeya
Old Aug 4, 2003 | 09:32 PM
vettenuts's Avatar
vettenuts
Default Re: Manual Transmission Fluid ('97 C5)
This is not a full synthetic, and the jury is still out about whether there are any adverse effects of using this fluid. Some are using it with great success though.
Old Aug 4, 2003 | 10:47 PM
IMQUIK's Avatar
IMQUIK
Here we go again :crazy: AMSOIL ATF!! :banghead:
Old Aug 5, 2003 | 02:33 PM
carpe dm's Avatar
carpe dm
Amsoil. :yesnod:
Old Aug 5, 2003 | 05:57 PM
luvinc5's Avatar
luvinc5
Default Re: Manual Transmission Fluid (carpe dm)
I have Mobil1 ATF in the tranny case for 1 yr now. Results and observations: easier, smoother shifting. Chances are any synthetic ATF will provide the same results. Pick your synthethic brand and change the tranny fluid.
Old Aug 5, 2003 | 08:13 PM
88sk's Avatar
88sk
Default Re: Manual Transmission Fluid (luvinc5)
auto tranny fluid is ok for 6spd.tranny,this is my first 6spd.?
Old Aug 5, 2003 | 08:58 PM
Mark 84ltblu
Curise-In V Veteran
Default Re: Manual Transmission Fluid (88sk)
Yes. The factory requirement is for ATF.
Old Aug 5, 2003 | 08:59 PM
speedyc5's Avatar
speedyc5
I changed to Redline at 24K, very nice improvement in terms of easier gear engagement. Seen alot of good replys for mobil 1. So at 36K I switched to mobil 1. I can only speak for my car but the mobil 1 made a nice improvement over the Redline. Easier to engage 1st and reverse.
Just my $.02.
:seeya :seeya :seeya :seeya
Old Aug 5, 2003 | 09:00 PM
chuckster's Avatar
chuckster
Synchromesh here... :smash: :smash:
To Manual Transmission Fluid
Old Aug 5, 2003 | 09:17 PM
clintw's Avatar
clintw
I switched from stock to Amsoil and felt an improvement and I have since switched the Amsoil ATF to Royal Purple Synchromax and felt an improvement.
http://royalpurple.com/scmax/scmax.shtml
Old Aug 5, 2003 | 11:23 PM
Jhubbard's Avatar
Jhubbard
Default Re: Manual Transmission Fluid (clintw)
How does one change the fluid? Is it hard?
Old Aug 6, 2003 | 12:37 AM
RWE 427's Avatar
RWE 427
Veteran: Marine Corps
Default Re: Manual Transmission Fluid (Jhubbard)
:iagree: Does anyone have a write up for us that don't have service manuals?
