OK. Done. What's Next!
Old Oct 13, 2003 | 10:54 PM
WellAdjusted's Avatar
WellAdjusted
From: His name is Tandy Dillen. Altruism is the last Frontier.
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
St. Jude '03-'04-'05-'06-'07
Default OK. Done. What's Next!
BW, GHL w/ Magnaflow X-Pipe in place and functioning well. (Sounds and runs great). Winter storage in the next month. Spring '04 budget will be more generous.
I've got a true C5 tuner 2 hours from home and will PCM Calibrate (DynoTech Engineering, Ft. Wayne, Indiana - full program with a file folder of print outs/dyno runs, etc.) for around $500-550 depending on the number of bolt ons in place at the time. I've got that program built into the budget for Spring '04.
In some semblance of order I want to do the following before I go to DynoTech for the Edit:
Long Tube Headers
Delete Cats
Ported Throttle Body
MAF coupler and sensor
Z06 AirBridge w/ smooth coupler to TB.
Spark Plugs & Wires (still debating on brand[s])
Tires (not an under-the-hood consideration)
Then, of course, the proverbial LS1 Edit, a.k.a. PCM Calibration.
Opinions are important to me. And yes, I'm still a bit of a noob. But I'm learning quickly.
Thanx in advance.
Michael :cheers:
Old Oct 14, 2003 | 05:27 PM
Rays Vet's Avatar
Rays Vet
Default Re: OK. Done. What's Next! (WellAdjusted)
Nice mods...... I would skip these 2 >MAF coupler and sensor
Z06 AirBridge w/ smooth coupler and do a cam change or something I am tossing around is the 1.85 rockers(Tbyrne running them on sale).More air out means more air in. ;) ;) ;)
Old Oct 14, 2003 | 05:59 PM
WellAdjusted
Cruise-In V Veteran
Default Re: OK. Done. What's Next! (Rays Vet)
Thanx Ray, come to think of it, it would be a good idea to do the cam at the same time as the headers as long as I'll have her guts in my lap already. :rolleyes:
Any popular opinions on cam/header combos?
Sincerely,
Noob
Old Oct 14, 2003 | 07:06 PM
EVIL's Avatar
EVIL
St. Jude Donor '03-'04
i say
heads
cam
headers
then get to the other stuff...you build a house you lay the foundation first....
how much you looking to spend? how much power do you want?
Old Oct 14, 2003 | 07:20 PM
WellAdjusted
Cruise-In V Veteran
Default Re: OK. Done. What's Next! (EVIL)
Good point. I'm a contractor by trade so this should be my approach.
Best Guess...... :rolleyes: How far will 2 Grand get me using professional volunteer (nearly volunteer) help and my assistance. I've got access to a C5 Hoist for $10/hour whenever I want it including all the tools in the garage.
:crazy: :crazy: How much power is there???? :lol: Seriously, I'd like to build a platform that will be blower friendly in a couple years as I tinker around and get more and more addicted to C5G-Force. :thumbs:
Thanx Evil. :seeya :cheers:
Old Oct 14, 2003 | 11:27 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
I would look into doing a cam and some long tubes if you don't have alot of money to throw around. There are some good low cost heads available also. I did my heads/cam w/ a buddy of mine in his garage. It was pretty easy. Saved 2k on instal. Kaley
Old Oct 15, 2003 | 08:50 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: OK. Done. What's Next! (2C5only21)
A good stainless steel long tube header and larger diameter stainless steel x-pipe center section is what I would recommend doing next. This will set you up for further engine mods in the future like a cam and/or heads. Depending on what setup you went with, its a pure bolt-on too, not welding required.
The ported throttlebody gets you maybe a few HP and a bit better throttle response if done right. I would probably hold off until you do heads/cam or something of the like before I did that.
You already have the larger 01 MAF, so nothing needs to be done there. An airbridge/coupler may get you a couple HP and improve the looks under your hood.
Spark plug and wires are a good idea.. Id go with NGK TR55s and a good set of magnecore or taylor wires.
Tires are also an excellent mod that you will notice each and everytime you drive the car: improved handling, less road noise and better straight line traction.
If you have any questions about anything I mentioned above, or are interested in pricing, feel free to drop me an email!
[Modified by MattG, 8:51 AM 10/15/2003]
Old Oct 15, 2003 | 11:54 AM
Rays Vet's Avatar
Rays Vet
Just food for thought.....Be careful with the cam selection if your intent is to get a supercharger,blower,or if you decide on nos.The specs. for these power adders is considerably different.Even I think the head mod will dictate the amount of compression you might would use versus how much turbo boost you can practically get away with.BTW you have i.m.
Old Oct 15, 2003 | 08:28 PM
WellAdjusted
Cruise-In V Veteran
Love this forum.
Let's assume first that my conservative mod budget for Spring '04 of $2K could just as easily be double that, or more, depending on how the winter goes. I'm planning a 7 night trip to Phuket, Thailand in April so I don't want to overshoot and get my hopes up unnecessarily. Hence, the conservative budget projection.
Second, let's understand that I do nothing half-azzed. And I only do each thing one time and one way. The right way. ESPECIALLY when it comes to my baby. :yesnod:
So!
Cam: $?,???.00
Heads: $?,???.00
Headers: $???.00
My labor and the fact that I made good choices early on as a smart little Noob and now have the foundation for a ProCharger:
Priceless!!!!!!!! :thumbs:
Now, anyone able to turn the "?"s into numeric figures?
Thanx.
Michael. :cheers: :seeya
Old Oct 15, 2003 | 11:29 PM
MattG's Avatar
MattG
Michael, you have mail! :seeya
Old Oct 16, 2003 | 12:10 AM
WellAdjusted
Cruise-In V Veteran
Default Re: OK. Done. What's Next! (MattG)
Matt,
You too have mail. Here's the thing. Your car .................. isss..................
I think immumbbee. ......... blarp............ :U
Your car is freakin' sick, Dude. :smash: :thumbs: :cool:
You 'da man, Matt. If I EVER get that :cool: I will be sure and e-mail you :lol:
:cheers:
To OK. Done. What's Next!
