ls1 manifold removal
Old Jan 19, 2004 | 07:41 AM
wrustywrench's Avatar
wrustywrench
Default ls1 manifold removal
I am asking instead of looking in the books,, does antifreeze have to be drained to remove the intake manifold, ???
Old Jan 19, 2004 | 08:01 AM
Mr. Jones's Avatar
Mr. Jones
Default Re: ls1 manifold removal (wrustywrench)
no
but the throttle body coolant tube will have to be plugged.
if you are going ls1 to ls6 intake you will have to install coolant
bypass plugs in the rear section of the head. still no big deal.
have parts ready to swap-work fast :lol:
[Modified by Mr. Jones, 8:04 AM 1/19/2004]
Old Jan 19, 2004 | 10:10 AM
jmX's Avatar
jmX
This is an LS1, its like no other engine ;)
Check this out for some basics http://www.ls1howto.com/index.php?article=5
Old Jan 19, 2004 | 10:53 AM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Default Re: ls1 manifold removal (jmX)
If you want to leave the TB lines hooked up, just unbolt the TB and pull it forward a little. Once you have done it a few times, you can swap intakes in less than 1/2 hour.
To ls1 manifold removal
