Help!! Where is the Blower Motor Relay (HVAC)
Old 07-04-2016, 08:07 AM
ERIC_MEMS1@YAHOO.COM
ERIC_MEMS1@YAHOO.COM's Avatar
Default resistor
Originally Posted by Bill Curlee
ABSOLUTELY!! We need to know what system you have before we can properly respond.. Duel Zone or Manual System? Year C5??
BC
Bill mine is a 06, c6 Manual with dual zone climate control
Old 07-04-2016, 11:55 AM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Eric
The C6 system is significantly different than the C5 HVAC System. I would have to do some digging in a C6 tech manual to answer your questions for a C6 system...
Old 08-06-2016, 09:01 AM
ls2SS
ls2SS's Avatar
Send to me as well
Jackie.harrisjr@comcast.net
R&R procedure if someone would please!! Good paperwork to keep in glove box in the event of an issue
Old 08-14-2016, 08:27 AM
Gixxer1on1
Gixxer1on1's Avatar
Sorry to hit up an old tread. I posted a new one but thought people might be more likely to it on an older thread.
I looked at the wiring diagram and it looks like the blower motor has a relay before the 5 position switch (manual air on a 99 frc). Mine is working just as it is supposed to and I replaced the resistor just hoping that is the problem. It works even with the switch off. I can turn it off with the switch and on every setting. But the key isn't in the car!!! Lol
Not a big deal til I forget to turn it off and drain the battery. I think maybe the really before the switch is stuck on. If that relay exist. I can't find it. I know there is one built into the resistor but since I just replaced it and the old one didn't even look bad. I can't really believe that is it. Any advice is appreciated!!
Old 08-14-2016, 09:02 AM
Rob 02
Rob 02's Avatar
The rat that was running on that wheel must have been preparing for the Olympics.
Old 08-14-2016, 03:10 PM
wheelswheeler
wheelswheeler's Avatar
Hi all great stuff here and exactly what I was looking for, I think. I suck at all electrical probs but not afraid to try. My fan quit working this week and it sounds like the relay from what I'm reading here. So could I get the R & R as well from some one? 2000 Coupe with dual control manual.
Thanks to all once again!
rfwkr2004@gmail.com
Old 04-22-2017, 04:53 PM
Camberlink
Camberlink's Avatar
Bill I have a 2003 z06 and all of a sudden the blower motor stopped working can you send me the r&r procedure ?
camberlink@yahoo.com
Old 04-22-2017, 11:57 PM
Terry M.
Terry M.'s Avatar
Just emailed it to you. Good luck.
Old 04-23-2017, 02:38 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The fan control module (with relay) is located on the bottom of the HVAC air box. Follow the wires from the motor to the controller. If you have dual zone climate control, the module logic controlled and is expensive.
Bill
Old 05-09-2017, 01:25 AM
Camberlink
Camberlink's Avatar
Bill
bill I have dual zone climate control do you by chance have the part number for the controller?
Old 05-09-2017, 06:53 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here is a picture o a disassembled controller and you can see the part number on it:
EZ Slider (01-21-2023)
Old 06-05-2017, 01:39 AM
knr13
knr13's Avatar
Okay this is what I have going on I'm working on a 2002 ZO6 with dual climate control I have checked all the fuses removed the blower motor bench tested it and she works fine checked all the connections everything looks okay I did have this problem a few months back and I wiggled the plug back and forth took it in and out replaced it and it came back on but now nothing I did check voltage at the plug I'm getting approximately 13 volts when A/C is on I also checked voltage while the fan motor is connected and it seems like I'm not getting anything disconnected the blower and i get voltage comes back.. I did Run and Jump ground to the blower while its connected to the plug and it comes on at full speed so what do we think it is? thanks
Old 06-05-2017, 07:55 PM
  #33
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Sounds exactly like you have a bad motor control module. Have you taken it apart and looked for vaporized circuit traces or burnt components???
If the high current side of the module is bad, you could see battery voltage with the motor unpluged and no voltage with it plugged in.
When the circuit dies, it will let the voltage signal through but will NOT pass enough current to drive the motor.
Old 06-05-2017, 09:32 PM
  #34
knr13
knr13's Avatar
no bill I have not taken apart the module yet I just went ahead and purchased one should be in by tomorrow after reading this whole thread it all leads to the module thanks for the pic bill hopefully this will be the fix and I can be cool again I'll keep you updated
Old 06-09-2017, 05:51 PM
  #35
knr13
knr13's Avatar
where does the ground on the control module lead to or from?
Old 06-10-2017, 12:22 AM
  #36
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
USE AN ohm mETER AND READ THE BLACK WIRE TO A known good ground. sHOULE BE VERY CLOSE TO zero ohms..
G-202 is at the base of the A pillar You hae to remoe the sill cover to see it.
Passenges Door and A pillar base:
Old 06-11-2017, 02:18 AM
  #37
knr13
knr13's Avatar
thanks again Bill but do you think its ok to run a new ground or is the original shared with any other ground ?
To Help!! Where is the Blower Motor Relay (HVAC)
Old 06-11-2017, 08:52 AM
  #38
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Bud,, A ground is a gound. Running another wire is fine BUT, If it were me, I would just fix whats there. The wire from the fan to the splice pack and the ground lug is not that long or dificult to find.
Bill
Old 06-11-2017, 02:19 PM
  #39
knr13
knr13's Avatar
Bill
found it and its blowing cold thanks bill you
Old 07-12-2017, 11:12 AM
  #40
phil hunter
phil hunter's Avatar
Drove my car over to have lunch with friends. A/C worked great. Come out and start the car, no blower fan. Car is 2001 with dual controls, fuses are good and blower motor never made noise or vibrated. Anyone know the part number for the dual control module?
Phil
Quick Reply: Help!! Where is the Blower Motor Relay (HVAC)
