Is it this simple???
Old Mar 1, 2004 | 09:40 PM
Mac78and2K's Avatar
Mac78and2K
Default Is it this simple???
I have a 2000 coupe and my friend may sell me his polished wheels and tires off his 2003 with only 1600 miles. I know I will need to swap out the sensors. Is all I need to do is break down the 2003 wheels just enough to remove the 2003 sensors and install my 2000 sensors (after breaking down my 2000 tires) in the wheels and put the wheels back on the correct side for the sensor? I will put the 2003 sensore in my painted 2000 wheels and sell them. Sound like a good plan?
-Thanks
Old Mar 1, 2004 | 09:56 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Default Re: Is it this simple??? (Mac78and2K)
I wouldn't call that simple...simple would be just bolting on the wheels and :steering:
But yes, your plan should work just fine. You'll need to buy new O-rings for your 2000 sensors before you mount them in the new wheels though. You can get them at any hardware store or Home Depot, just take one with you once you get the old sensors out and match it up.
The 03 sensors uses a reusable rubber washer instead of O-rings and you can install those sensors into your old wheels as-is.
:cheers:
[Modified by Y2Kvert4me, 8:57 PM 3/1/2004]
Old Mar 10, 2004 | 10:56 AM
Mac78and2K's Avatar
Mac78and2K
Default Re: Is it this simple??? (Y2Kvert4me)
Thanks for the input. Does anyone know the type and size of the O ring so I can get them in advance?
Old Mar 10, 2004 | 01:11 PM
Your plan will work just fine. :thumbs:
Old Mar 10, 2004 | 01:44 PM
Patches's Avatar
Patches
The '97-'00 part # for the O-ring on the wheel tire pressure sensor is 10268438.
To Is it this simple???
