Ford SVO 30# injectors
Old Mar 4, 2004 | 01:48 AM
devo's Avatar
devo
St. Jude Donor '03 & '05
Default Ford SVO 30# injectors
Why would you need these injectors?
I was looking around in techtips and came across this.
Are they for supercharged/turbo apps? or just an upgrade...
Old Mar 4, 2004 | 01:59 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: Ford SVO 30# injectors (devo)
You need larger injectors when your fuel requirements increase. If you leave your engine stock, your OE injectors are just fine.
VR :cheers:
Old Mar 4, 2004 | 02:10 AM
kumar75150's Avatar
kumar75150
Default Re: Ford SVO 30# injectors (vetterdstr)
I'd say once you pass about 420rwhp, those are probably needed and should be good until a lil over 500rwhp.
Old Mar 4, 2004 | 02:17 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: Ford SVO 30# injectors (kumar75150)
:iagree: :thumbs:
Old Mar 4, 2004 | 02:48 PM
SFVetteman's Avatar
SFVetteman
Default Re: Ford SVO 30# injectors (LittleBoyBlu99)
I believe that once you exceed an injector duty cycle of 80%, you should go to larger injectors. It is not that they won’t work correctly above the 80% level, they will. However, most tend to agree that reliability of the injectors is compromised.
With a Blackwing, WCC MAF, and LS6 intake, I make 325 rwhp running very lean at WOT. Ease traces also showed that I was exceeding 80% duty cycle, at times, on the stock injectors. The following month when my H/C was done, I switched to SVO 30# injectors. They work well for me and are cheaper than other alternatives :cheers:
Old Mar 4, 2004 | 03:49 PM
pdd000's Avatar
pdd000
Default Re: Ford SVO 30# injectors (SFVetteman)
i went with accel 30iber's :cheers:
To Ford SVO 30# injectors
