NOISY HEADLAMP MOTOR
Old Mar 19, 2004 | 08:26 PM
DeeGee's Avatar
DeeGee
Default NOISY HEADLAMP MOTOR
Just developed a wierd noise. When the headlights turn off and stow, the drivers side motor carries on running with a loud clicking noise. The manual **** on the top carries on rotating so the motor is still running. The passenger side shuts off straight away normally.
Anyone had the problem. Any advice?
Old Mar 20, 2004 | 09:00 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: NOISY HEADLAMP MOTOR (DeeGee)
probably need to rebuild it....cheap and easy....heres my thread with pics and info on where to get the parts etc.
http://forums.corvetteforum.com/zerothread?id=711276 :seeya
hope this helps
[Modified by pewter99, 9:01 AM 3/20/2004]
Old Mar 20, 2004 | 05:24 PM
DeeGee's Avatar
DeeGee
Default Re: NOISY HEADLAMP MOTOR (pewter99)
Thanks!
Old Mar 20, 2004 | 06:17 PM
NOSLOW's Avatar
NOSLOW
My '97 has been doing the exact same thing for the past few months. The good news is that there's no immediate rush to fix it (if you don't mind that awful noise). I bought a used motor off the forum here and will put it in when I get around to it...hopefully that's before it totally burns out.
Gary
Old Mar 20, 2004 | 07:20 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: NOISY HEADLAMP MOTOR (NOSLOW)
The drive gear is worn out and needs to be replaced. There are people on the forum who sell brass gears that will eliminate that problem! Rebuilding the motor is easy once you have it out! I recommend rebuilding the motor that you have.
BC
Old Mar 20, 2004 | 07:23 PM
JSlyter's Avatar
JSlyter
I just had this happen happen on my passenger side headlamp. I had my service advisor look at it since I was in the neighborhood . He poked one of the stops with his pen and it took care of the problem. Finished my errands, only to find the problem had returned when I tested it a few hours later. Wondering if I messed something up. I just replaced my fogs with PIAA's a couple of days ago, but not sure if my problem is just a coincidence since I did night driving right after the install and everything worked fine.
Old Mar 21, 2004 | 12:01 AM
DeeGee's Avatar
DeeGee
Default Re: NOISY HEADLAMP MOTOR (JSlyter)
Thanks for the comments. I was just about to fit euro headlights so I'm glad I hit the problem before I started playing!
Old Mar 21, 2004 | 12:55 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There are rubber stops that tend to rot and crack. Try replacing the rubber stop before rebuliding the motor.
BC
To NOISY HEADLAMP MOTOR
