What's the difference other than 1 CI
Old Mar 20, 2004 | 11:28 AM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Default What's the difference other than 1 CI
What is the difference between a 382 and a 383. Is it just CI or something else. Is one better for FI................I know I am clueless :confused:
[Modified by Z06GMAN, 10:29 AM 3/20/2004]
Old Mar 20, 2004 | 12:56 PM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Default Re: What's the difference other than 1 CI (Z06GMAN)
Well anyone know :confused: :cheers:
Old Mar 20, 2004 | 02:01 PM
flynbludream's Avatar
flynbludream
Yes it is just 1ci difference the the main difference is how you get there. I believe you get the 382 by stroking stock CI, you get the 383 by boring the block with the stock crank.
Old Mar 20, 2004 | 02:47 PM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Default Re: What's the difference other than 1 CI (flynbludream)
HMMMMMMMMM Thanks so what way would be best for FI heavy boost???
Old Mar 20, 2004 | 05:36 PM
flynbludream
Opinions vary, for SC's people think the stoker is the way to go since it will help low end torque before the SC hits full boost. For a Turbo I think I would rather go all bore which will allow you to run it at higher RPM's. You can make up lots of area under the curve if you size your turbo to your desired max RPM. All bore should also allow you to run better heads(bigger valves, more hp with less boost) without shrouding issues.
To What's the difference other than 1 CI
