CAGS install, searched but ??
Old Apr 2, 2004 | 04:07 PM
skip89's Avatar
skip89
Default CAGS install, searched but ??
Want a good thread to CAGS install with pictures, doI need pictures ?
Old Apr 2, 2004 | 04:25 PM
Avanti's Avatar
Avanti
Default Re: CAGS install, searched but ?? (skip89)
I don't have one, but you really don't need one.
The most difficult part is deciding how you are going to get under it to do the job. I backed mine up on a couple 2X12s under each rear wheel, unplugged the CAGS wire at the tranny (left side), plugged in the two "plugs" of the eliminator into the respective tranny plug and into the harness, and used a wire tie to make sure the wires were out of the way.
Took longer dragging over the boards and backing up the car than doing the job. (oh yeah, as the instructions said, I did unhook the ground cable at the battery.)
All the best. :yesnod:
Old Apr 2, 2004 | 04:30 PM
Charlie LI NY's Avatar
Charlie LI NY
here you go. :seeya
http://www.97vette.com/howto/cags/index.html
Old Apr 2, 2004 | 06:00 PM
skip89's Avatar
skip89
Default Re: CAGS install, searched but ?? (Charlie LI NY)
Very nice, thank you. I hate to start without good directions... :D :) :chevy
Old Apr 2, 2004 | 11:23 PM
Cajun99's Avatar
Cajun99
The link to 97Vette's guide is about the best tutorial if you haven't done it.
Technically you're not doing a CAGS install (the Factory was kind enough to do that for you). You're doing a CAGS Defeat install... :p: :D :jester
Old Apr 4, 2004 | 11:01 AM
CR555's Avatar
CR555
Two more links: http://www.corvettedreams.com/cags.htm and http://www.ls1.com/link_cags.html :cheers:
To CAGS install, searched but ??
