i was their, my 60 ft was 2.03 but trapped 121.5 absolutely no traction :cuss :cuss :cuss :cuss so which drag radfials are you running the g-force or comp t/a version?????????????
Look up & read>>> BFG Drag Radial COMP T/A.. :yesnod:
After the first 3 spin runs from them scraping the track, I hooked up BIG TIME! :steering: :thumbs:
I had some great 60' for my mods with the BFG drag radial when I could get them to hook. Out of 4 runs I could on get them to hook one or two times, it just depended on the track prep.
I went to the M/T ET Streets, which hook very consistantly but I lost 3-4 mph in the 1/4 and approx. .2 in ET
1.61 on 315-17s and 1.60 on 315-18s. The weather was slightly better when I ran the 18s. If the track is prepped and the tires are rather fresh, either tire will work as well, all else being the same. I do like the 18s a little better as they are stealthy.
