trans cooler install
Old May 15, 2004 | 10:20 PM
414a4coupe's Avatar
414a4coupe
Default trans cooler install
when installing a cooler should i route the trans fluid through the radiator and into the cooler or eliminate the radiator and just run it through the cooler only?if i route the fluid through the radiator does the cooler go in the top or the bottom line on the radiator?
Old May 16, 2004 | 01:09 PM
carpe dm's Avatar
carpe dm
Default Re: trans cooler install (414a4coupe)
Use the radiator and the top line is the one you want. :)
Old May 16, 2004 | 04:58 PM
IMQUIK's Avatar
IMQUIK
:lurk:
Old May 16, 2004 | 07:22 PM
devo's Avatar
devo
St. Jude Donor '03 & '05
:lurk: :lurk: :lurk:
To trans cooler install
