need help replacing reverse syncro and fork
Old Aug 4, 2004 | 06:05 PM
happyhourvette's Avatar
happyhourvette
Default need help replacing reverse syncro and fork
i have a 2000 6-speed the trans pops out of reverse . i am told that it's probably the reverse syncro and or the shifting fork.c-tech says i can change these parts without completly removing trans.he has always been right with his info before,but i don't know what he means i need more instruction thanks in advance for any tips i am going out to remove rear gear i will check back a little later
i am back again i have removed all rear suspension. i have not taken the transaxle away from trans. yet but it's ready.i am not sure if i should remove it or not.so i will wait to see if anyone has any ideas. i hope c-tech sees this post
Old Aug 4, 2004 | 09:18 PM
silverz06vette's Avatar
silverz06vette
Not sure if it has to be removed, but here is a link to the manual:
http://www.ttcautomotive.com/english...ice_Manual.pdf
Old Aug 4, 2004 | 11:51 PM
rodney@rpmtransmissions's Avatar
0rodney@rpmtransmissions
Former Vendor
Give me a call 765-524-5341
To need help replacing reverse syncro and fork
