ptk or hp turbo will be installed late this fall. forged motor to be built w/8.75 compression. 03 w/c6 pump and goals are as much as possible on pump gas, wiil run alchy. need fuel help. this is what iam thinking:
ls1 speed rails
external walbor pump using -8 feed and stock lines for return.
mod top of the pump module for access for new feed line
is is possible to mod hanger and use daul in tank pumps?
if i use external what brand will work the best but also be QUIET!!!!
I do not think you will need dual intank pumps. The Racetronic intank pump with a Kenny Boost-A-Pump should supply more than enough pressure as long as the pressure is regulated at the fuel rail. If you are running -8an SS braided line, use an inline filter that flows at least 340 gph.
Keith
Thanks Keith,
but no Racetronic pump available late 03 c6 style.
What now?
