Really stupid question.
Thanks.
With great humbleness,
Mike
and while you're at it, get a K&N or Fram AirHog filter. Mike
Mike
Just order Z06 Air Box Part # 12567571 from www.gmpartsdirect.com
$47.00 delivered.
Unlike the 00-04 airbox, the stock 99 air box is totally enclosed on the top of the airbox.Tom
An easy mod to make is to take the top cover off your airbox and cut the center out. If you look at the inside, it'll be obvious where you can cut (about a 4" x 6" center hole) and leave the reinforcements for the metal straps to still work.
I did this and picked up about 9 rwhp according to the dyno.
Also, a good paper filter will flow as well as, and filter better than, an oil gauze filter (which I own). They need to be replaced more frequently, and they might be more sensitive to water spray, but I'm pretty well convinced that the gauze filters are more hype than anything else.
Of course, hype sells well.
HTH, and have a good one,
Mike
