Need help lowering in missouri.
Old Nov 6, 2004 | 11:47 PM
STA-BLK's Avatar
STA-BLK
Default Need help lowering in missouri.
I know what your all gonna say but im stuck.I just installed my ti exhaust and decided to lower the ride as well but i cant get the front bolts to turn at all.It sets at ground to fender about 28 inches in the front and it looks horrible.(2000 hardtop).Im willing to make it worth anyones while to help me get this thing lower.The front pass side bolt seems like it wants to round off so im a bit scared to try any more.Ant takers?I have a heated cooled garage and all the tools to do the job i just need an extra set of expert hands(dont even!).Thanks!
Old Nov 7, 2004 | 12:45 AM
MTWallet's Avatar
MTWallet
Sent you a PM.
Old Nov 7, 2004 | 01:10 AM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
Where in MO. are you????
Old Nov 7, 2004 | 02:27 AM
TheDVS1's Avatar
TheDVS1
After lifting the car and supporting it on stands, slightly jack up the front spring on the side you're trying to lower to relieve pressure on the bolt. Use a 10mm wrench, spray some WD-40 on the threads and bushing and go for it. Make sure you're turning the bolt counter-clockwise to lower.
Old Nov 7, 2004 | 09:48 AM
STA-BLK's Avatar
STA-BLK
Im in springfield but ill drive anywhere in reason for some help.Thanks guys.
Old Nov 7, 2004 | 09:50 AM
STA-BLK's Avatar
STA-BLK
The spring is not actually sitting on the washer/bolt.It looks like it is a bout a quartor inch above it.Do i still need to relive pressure by jacking the spring up?
Old Nov 7, 2004 | 10:21 AM
GOOSE JR.'s Avatar
GOOSE JR.
Give ALLCAR a message he'll talk you thru this little problem.
Old Nov 7, 2004 | 10:34 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
The bolt is threaded through the spring, so, yes there is considerable tension on that bolt, making it very tough to turn. By jacking the spring up, you remove much of this tension, making the bolt usually very easy to turn.
That 1/4" gap you see between the bottom of spring and the bushing (which is actually the bottom of the bolt) is the gap you will eliminate when you thread the bolt upwards into the spring. The spring tension remain the same no matter how much gap or space there is between the bushing and the spring.
Now, if you had a gap between the bottom of the bushing and the Lower control arm, THEN you'd have removed all tension on the spring.
Old Nov 7, 2004 | 10:46 AM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
Old Nov 7, 2004 | 11:28 AM
STA-BLK's Avatar
STA-BLK
Well you sir have found my problem.I was under the assumption that the spring rested on the washer/bolt.I had no idea it was threaded into the spring as well,so i thought i would have to thread the bolt farther into the a arm.Ill be trying again tonite!!!
Old Nov 7, 2004 | 11:47 AM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
And FYI, you'll want to turn the 10mm hex head of the bolt counterclockwise, as if you were loosening it. This will thread the bolt up into the spring, whcih is what you want to do to lower it.
Jacking up on the spring to relieve the tension will make all the difference in ease of turning the bolt. Good luck to ya.
Old Nov 7, 2004 | 03:16 PM
STA-BLK's Avatar
STA-BLK
Front is done im jacking the rear as we speak.Oll keep you posted guys.Thanks for the help.
Old Nov 7, 2004 | 04:01 PM
STA-BLK's Avatar
STA-BLK
Ok done the front took about 45 mins and the rear was an easy 10 min.It doesnt look a whole lot lower but it dropped so far before driving it 1 full inch.Hope it drops at least half again as much but im sure ill need to remove some bushings to be happy.
Old Nov 8, 2004 | 12:11 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
The car does not settle right away, it will drop more..
here is my car after five years on lowered stock bolts only
Old Nov 8, 2004 | 12:12 AM
STA-BLK's Avatar
STA-BLK
Stock bolts?No cutting at all?That is exactly what im looking for!
To Need help lowering in missouri.
